Squeaky poly sway bar bushing
Old Aug 12, 2020 | 10:53 AM
jrp1588's Avatar
jrp1588
Default Squeaky poly sway bar bushing
My rear bushings were shot, so I replaced them with a poly set a few months ago. They're ALREADY starting to squeak, mostly the driver's side when taking off around corners. I don't want to have to regrease these every couple months. I've seen bushings available for other cars that have a teflon liner on them that are supposedly greaseless. Do these exist for our cars? Is there a durable teflon tape of some sort I can wrap around the bar to serve the same purpose? Should I just drill the bushing and mount to accept a zerk fitting or something?
Old Aug 12, 2020 | 03:55 PM
oharal's Avatar
oharal
I think mine start to squeak enough to bother me enough that I grease them once or twice a year, but my car hasn't gotten the normal level of use for the last year for a number of reasons. What grease do you use?
Old Aug 12, 2020 | 03:56 PM
jrp1588's Avatar
jrp1588
I DD mine, so it sees a fair amount of use.
Old Aug 12, 2020 | 03:58 PM
oharal's Avatar
oharal
You replied faster than I could finish my post after finishing it once lol. What grease are you using?
Old Aug 12, 2020 | 03:59 PM
jrp1588's Avatar
jrp1588
I've only greased it once when I installed, but it was whatever came with them. I think they were Prothane.
Old Aug 12, 2020 | 06:56 PM
Fast one's Avatar
Fast one
Without grease fittings you can't grease them at all unless they are disassembled and the original grease has a finite lifetime. After a few years mine were squeeking and when they were taken apart there was wear from lack of grease so they were cleaned and grease fittings were added. After a year there is no squeeking and while the car is up for other work I'll give them a shot of silicone grease so they remain lubricated.
Old Aug 12, 2020 | 08:37 PM
JBird3's Avatar
JBird3
Just grease 'em and it'll go away. It lasted forever the last time I did it.
Old Aug 12, 2020 | 09:50 PM
jrp1588's Avatar
jrp1588
I can't grease them without taking the whole bar off, which would suck since the last application only lasted a few months. Granted, the bar slid like 2 inches off center before I applied some clamps, so I may have lost much of ther grease.
Old Aug 13, 2020 | 08:24 AM
Budwise's Avatar
Budwise
Wrap the bar in yellow teflon tape, then grease, then reinstall bushing.
Old Aug 13, 2020 | 08:32 AM
jrp1588's Avatar
jrp1588
You have a link? The only tape I could find was thread seal tape for plumbing, and some specialty discontinued GM stuff.
Old Aug 13, 2020 | 12:59 PM
oharal's Avatar
oharal
I use a marine grade grease that stands up to water exposure and it's a maintenance item for sure but manageable.
Old Aug 13, 2020 | 08:45 PM
Budwise's Avatar
Budwise
Yep, the same thread sealing tape plumbers use. Can get at home depot for a few bucks.
Old Aug 13, 2020 | 08:47 PM
jrp1588's Avatar
jrp1588
Really? There's no adhesive. Figured it would just kind of slough off. I have like 5 rolls of the blue stuff because I can never remember if I have any when I'm doing a plumbing project.
To Squeaky poly sway bar bushing
