2000 c5 corvette Shift cable
Old Aug 14, 2020 | 10:05 PM
thevelvetglove's Avatar
thevelvetglove
Default 2000 c5 corvette Shift cable
HELP- Hi all I have spent a week trying to locate a gear shift cable for a 2000 4 speed c5 corvette, but no-one has one any ideas... I live in Hawaii
Old Aug 15, 2020 | 06:45 AM
awches's Avatar
awches
Probably have to order one from the mainland. Even EBay has them.
Old Aug 15, 2020 | 01:14 PM
GCG's Avatar
GCG
Unless you know for sure the cable is damaged, I would suggest doing a little double-checking first.
Usually the cable is fine and is just a broken bushing at one of its ends.
Even though most probably only 1 gave up, this is a call to replace bushings at both ends.
All that's needed is the
<b>Dorman 14057</b> Dorman 14057
kit. Use the white bushings (the orange ones are for Ford):
And
shows how to do it.
A little dielectric grease combined with long channel-lock pliers will make things a lot easier when installing the bushings. Just get 2 pieces of cardboard or something similar and tape them over the grooves in the pliers jaws to protect things when pressing the bushings in.
This is very doable and it's just a few bucks and a couple of hours to change the bushing at both ends of the cable, taking your time
Old Aug 16, 2020 | 01:17 PM
thevelvetglove
Default c5 corvette Gear shift cable
Thanks everyone, I was trying to replace the bushing on the shifter end and snapped the case that holds cable. I have a c5 4 gear trans, and there is a different shift cable for a 4 gear trans than the six gear trans . I need the cable for the 4 gear trans which is a little shorter than the six speed. thanks
I can find almost any cable on ebay etc except for my application
Old Aug 17, 2020 | 02:09 AM
GCG's Avatar
GCG
Sorry to hear that. I don't know if you already have the correct Part No., but just in case it might be of help here they are:
The part number for the shifter cable from 97-03 is 12561688
The part number for 04-05 (and late 03) is 10352529
To 2000 c5 corvette Shift cable
