*#!!! Squirrels .. No Fuel Pressure
Old Aug 19, 2020 | 09:38 AM
rudystrick's Avatar
rudystrick
Default *#!!! Squirrels .. No Fuel Pressure
99 Corvette, Sat up for a while (long story).. wiring chewed by squirrels. I am attempting to get it running again. I am losing pressure to the tank. If I use a cheat wire to fuel pump it cranks.. but without cheat wire the fuel pump will not engage. Relay is good.. So we are assuming the problem is in the Fuel pressure regulator or possibly evap system.. does anyone have a diagram of fuel pump, regulator and evap wiring?? (not rocket scientists here,, the more BASIC the diagram is the better it will be) .. thank you..
Old Aug 19, 2020 | 02:42 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Ok, we are going to have to get REAL basic here...where did you install this “cheat” wire...we normally call it a jumper wire..how do you know you are losing fuel pressure to the tank ??...fuel pressure gauge ??..fuel pressure regulator or EVAP system does NOT have anything to do with your concern !!
