For those who have rebuilt their transmission where have you purchased your input/output shaft seals? The ones that came with my kit are apparently for your general 4L60E’s and are just slightly to big.
Check RPM Transmission - they rebuild these and I'm sure can source parts.
I ended up going to a dealership and they pulled up a part number that I had cross referenced from ac Delco. Even ac delco showed the same part that I have as a part that fits, makes no since. Dealership couldn’t order it but I found it on amazon for about $36...😒Transmission output seal #24228816
Reason: Forgot to add
