Specific overheating problem, please help!
Old Aug 23, 2020 | 03:29 AM
1999corvettels1's Avatar
1999corvettels1
Originally Posted by twostepdon
Both fans come on at low speed or high speed. As for as temps this is a quote from Evil Twin
FYI:
Depending on the model year...
For later model years:01-04
The low speed cooling fans are commanded on when the coolant temperature reaches 108°C (226°F). They are turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fans are commanded on when the coolant temperature reaches 113°C (235°F). They are turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fans will be turned on at vehicle speeds less than 56 kPh (35 mph).
For early model years:97-00
Low speed fans come on at 219,high speed fans come on at 228,low speed with a/c on...
At least on my 1999 that is factory, it does what you explained the 01-04 years do.
I've watched the digital temp read out and see/hear the fans come on at 226.
Old Aug 23, 2020 | 01:26 PM
GCG's Avatar
GCG
Originally Posted by JDMricist_03
...it looks like the drivers side fan isn't spinning but the passenger's side fan turns on at about 225ish. The driver side fan is supposed to be spinning before the passenger side fan does right?
That's your problem right there.
As mentioned above, in a C5, fans can run in Low or High Speed Modes, but in each case, both fans are supposed to run at the same time and at the same speed.
In Low Speed Mode fans are wired in series, with half the voltage applied to each one. In High Speed Mode they are wired in parallel, with full voltage to each one.
-Low Speed Mode (Series):
-High Speed Mode (Parallel):
