Rat bitten fuel hose
Old Aug 22, 2020 | 07:32 PM
Muguvian's Avatar
Muguvian
Default Rat bitten fuel hose
My 2001 coupe has been sitting outside for a while and has been housing rats over the transaxle . I turned the key and fuel poured out just in front of the rear wheel. Under I go and find that the rear tank return hose (hard plastic) is chewed through. They are no longer made and none of the salvage shops has one. So I tried to heat and bend a NAPA repair pipe. Yeah, right! Finally spliced in a piece of rubber hose, got it in and it worked. Then I found out there was another leak in the bundle of fuel pipes that go up from the fuel pump, through the frame, then split off to the filter and other places. I can’t see which pipe is leaking, but it’s not at the fuel filter. If I take off the left rear tire and it’s inner fender panel, will it give me access to the fuel pipes? Any other ideas? HELP!
