2001 Corvette Steering
Old Aug 19, 2020 | 09:02 AM
thelal1's Avatar
thelal1
Default 2001 Corvette Steering
Posting for a freind. Can start car up, mive forward and backwards. Cannot turn steering wheel in either direction. Column issue???
ted
Old Aug 19, 2020 | 10:08 AM
schmuckingham's Avatar
schmuckingham
Probably gonna need one of these:
LMC5 Column lock LMC5 Column lock
Old Aug 19, 2020 | 11:24 AM
thelal1's Avatar
thelal1
Default Steering wheel Locked
LMC5 Column lock
Thanks will relay that. Article states could be a blown fuse on motor that unthat unlocks wheel. Then if isn't buy this easy install kit.
Old Aug 19, 2020 | 11:29 AM
SilverC54me's Avatar
SilverC54me
First question, is this a manual transmission car? If so then you need to install the LMC5 and get the unlocker tool also.
If it is an automatic something else is going on. Automatics from 2001 up do not have the column lock from the factory.
Gary
Old Aug 19, 2020 | 12:24 PM
thelal1's Avatar
thelal1
Manual tranny, should have stated that.
Old Aug 22, 2020 | 08:49 PM
3sACROWD's Avatar
3sACROWD
It hasn't been mentioned. Get the battery load tested. Even though the car started, you may have a weak battery. This is a known contributor to the column lock problems.
To 2001 Corvette Steering
