Rotors
Old Aug 23, 2020 | 03:32 PM
Venom602's Avatar
Venom602
Default Rotors
Im new here and to the corvette world just got my 2001 c5 a couple months ago and now need to do some maintenance, wanting to change out the rotors and was wondering if these Wilwood rotors would fit my c5 or what i should get
2001 Chevrolet Corvette C-5 & Z06 - Front Brake Kit Part No.: 140-9336-D
Promatrix Front and Rear Replacement Rotor Kit
Old Aug 23, 2020 | 05:28 PM
scorpiofox69's Avatar
scorpiofox69
Depends on how you intend to drive the car. We need more information.
Tracking?
Spirited?
Weekend cruiser?
Daily driver?
Old Aug 23, 2020 | 06:20 PM
Venom602's Avatar
Venom602
Tracking?
Spirited?
Weekend cruiser?
Daily driver?
Daily driver/tracking eventually my plan is to add more power slowly throughout the next 2years, but im also not trying to spend a ton on brakes and rotors right now but not cheap it out
Old Aug 23, 2020 | 08:43 PM
Adwest52's Avatar
Adwest52
2021 C5 of the Year Finalist - Unmodified
Brake Motive is the way to go then. They have an Ebay store and a full set of drilled and slotted rotors and ceramic pads is only $175 with free shipping. I just installed them on my car and am absolutely thrilled with them. Oh yeah by the way the rotors are zinc plated for protection from corrosion.
Old Aug 23, 2020 | 08:54 PM
scorpiofox69
I did these rotors with Power Stop pads.
Old Aug 23, 2020 | 10:15 PM
Venom602's Avatar
Venom602
do you know if the wilwood rotors on my top post would work for the c5 without doing any modifications ? now sure if theirs a difference in rotor size since rim size is different from front to back, thats kinda what stops me from buying the front and back rotors together as a (package). Says it fits 01 corvette but i want to be 100% since its a decent amount of money
Old Aug 24, 2020 | 01:40 AM
strand rider's Avatar
strand rider
napa has good quality stuff that is often recommended by the track guys who buy a lot of rotors. Just avoid the lower line stuff , it is there to compete with loser priced auto parts chain stores, but is not always OEM quality.
Holes and cuts are just decorative cheese graters for your pads, unless you have issues with excess out gassing of the friction pads at speed. For street use, they are a cosmetic holdover from a different time, with different available materials, but do look real racey. It used to be one had to inspect the drilled rotors for cracks, but that seems to have changed, perhaps a different iron formula is now used.
Old Aug 24, 2020 | 09:31 AM
Venom602's Avatar
Venom602
so what would you recommend using? I rather stay away from the cheaper stuff forsure
Old Aug 24, 2020 | 09:54 AM
scorpiofox69
Assuming it is Part No: 140-9336-D, they work with OEM calipers. These are fairly expensive for what your stated purposes are, but it is ultimately your decision and wallet. Hope you are getting a helluva deal.
Old Aug 24, 2020 | 10:04 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Take a look at the Centric premium brand rotors plain face they are a great value along with the Carbotech 1521 brake pads you will be all set for street use or Auto X.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound’s excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Aug 24, 2020 | 10:42 AM
KNSBrakes's Avatar
KNSBrakes
Supporting Vendor
I would suggest that you do not put a drilled rotor on a car you intend to drive hard.
The most durable 1 piece blank is this one.
https://knsbrakes.com/c/car-series/1...-+Single+Rotor
Old Aug 24, 2020 | 01:09 PM
Venom602's Avatar
Venom602
hmm so many to choose from im cool with spending 300 on rotors but i just want something thats worth it a decent brand thats not going to fail me , i did just race a mustang today made him back down whats a top 3 choice for you if not these ? Ive seen powerstop but idkk
Old Aug 24, 2020 | 01:18 PM
scorpiofox69
My opinion (FWIW):
Brake Motive
Power Stop
Napa
I'll leave it to the track monster members to opine on the more heat tolerant heavy duty rotors...
Old Aug 24, 2020 | 01:26 PM
Venom602's Avatar
Venom602
My opinion (FWIW):
Brake Motive
Power Stop
Napa
sounds good ill take a better look at those. Should i buy a front and back kit? Are the fronts and back rotors same size ?
Old Aug 24, 2020 | 02:20 PM
Adwest52's Avatar
Adwest52
Front rotors are larger in diameter and thicker than the rear ones so therefore are not interchangeable. I always replace all four rotors at the same time when I do brakes.
Old Aug 24, 2020 | 03:39 PM
Venom602's Avatar
Venom602
so should i not buy a “kit” that comes with all 4 rotors? I was looking at rock auto online they have the kits or pairs but obviously search for veichle and they come up no choice in sizes
Old Aug 24, 2020 | 03:46 PM
scorpiofox69
Just select the 4 rotor set that fits your requirements-with or without pads. I did the Brake Motive rotors, then purchased Power Stop ceramic pads, separately.
Old Aug 24, 2020 | 03:50 PM
Venom602's Avatar
Venom602
alright sounds good thanks everyone for the replies. These forums have really helped me a lot since i purchased my corvette
Old Aug 24, 2020 | 03:55 PM
Adwest52's Avatar
Adwest52
That's why we are all members here to help each other out. It's a great community with a wealth of knowledge.
To Rotors
