ABS/Stability control
Old Aug 25, 2020 | 09:24 AM
aahrested's Avatar
aahrested
Default ABS/Stability control
I have a 1998, A4, A&A SC, LS3, Ever since I did the engine swap to the LS3, my ABS/Stability control doesn't work. I posted this issue a while back but, I hope a new set of eyes can help. When I spin the wheels, I get the message that the traction control was activated but, it wasn't, I could spin the tires all through 1st, and 2nd. I have no codes for this at all. With each press of the button on the console, the dash indicates that Stability Control is either on or off so, all of that is working fine, it just doesn't do anything. There are no broken wires, or bad fuses. I am at a loss, and after a car ran a red light in front of me a few weeks ago, I locked up the brakes, and learned that the ABS is also not working. Hopefully someone can point me in the right direction
