So im sure this isnt a new problem my cars overheating now, on the freeway iam getting right behind 220 with a/c on or off. When iam in stop and go traffic not even for long i get to 230 and slowly to 240 max if i dont move. If iam parked idle i pass 220 in like 2mins if i rev at 2k for a little i climb towards the 230 -240(a/c on or off) also but i let off by then and turn the car off. I changed the hoses today and going to fill up any missing fluids from what was dropped today if any later on when it cools down. Not sure whats wrong iam going to change thermostat next . Any suggestions my fellow Corvette Brothers/sisters (i have checked other threads seen pump could be it but i cant pay for that today i got a cat i need installed this monday)
1 Make sure the font of the radiator is not clogged up full of debris like weeds etc
2 Make sure the fans are coming on # 1 comes on at 226* # 2 on at 235*
3 Install a 160 thermostat
4 Have a mail order tuner reset your fan on/off temps #1 On at 200 OFF at 195--#2 On at 205 OFF at 201
5 make sure you "burp" the air out of your cooling system--(let the car warm up without the cap on -once the thermo opens it should burp out all of the air) refill radiator Air in your cooling system will make it overheat---
so my fans work i can hear them i see the one on right(passanger) moving also i would see my temps go 230s then back down to 220 then randomly back up and so on. I have cleared the air in the system. Whats up with that kind of thermostat? Whats the difference from my stock one ? Was planning on getting a new one tomorrow since its only like 20$
I suspect others will disagree with me but 220 degrees just driving on the highway at 60, 70, 80 mph is high; even in Arizona at 100 degree ambient. If you are having temperature problems at highway speeds it’s not the fans because they should not need to turn on.
Are you basically stock? Highly modified?
First things first, when was the car running at what you considered to be normal and was anything done to the car since then?
When you noticed this hot behavior, was your coolant level normal? Have you noticed a loss of coolant? If no coolant loss than that eliminates a leak and probably eliminates a blown head gasket.
Air side - no plastic bags blocking the condenser or radiator?
Coolant side- sticky or stuck thermostat, maybe. Plugged radiator tubes was a problem in the old days but long life coolants, regular changes, and aluminum radiators make that rarer. Hopefully your car has had the coolant changed at recommended intervals and with comparable coolant. Water pump-I can’t speak about a C5 but typically a pump is just an impeller and a housing. As long as it isn’t seized and doesn’t leak, it just spins and pumps. If your pump was seizing I have to think you would hear or smell the belt.
iam stock i shadow 220 on highway so right before getting to it my fans work they kick on and drop me back down at higher temps. My problem is in basic normal city traffic when i sit their waiting for the lights. My normal use to be 180 i would never pass that. i have only got new tires and changed my brakes so nothing really, no coolant loss or leaks. My radiator has very little leaves nothing that seems that serious or to cause blockage. I was planning to get a new thermostat tomorrow after work . i feel like the Rad might be clogged or something internally or pump but the pump seems fine slightly worn down on belt but nothing that seems like it would cause such an issue, pump doesnt leak. I might get a 180 thermostat not sure as long as i dont get check engine lights from the change. Temps have been at 115 also recently 100-115 in AZ
Is the front air dam in good shape? They tend to get damaged with time and the car will overheat or get very close to overheating when the car is not moving.if it is damaged or missing.
my air dam is good still their and intact . Iguess i could try cleaning what it does have and see what happens with the thermostat today.
Sudden changes to operating temperatures and specifically during stop and go traffic sometimes means that one of your fans is not working, as mentioned in previous posts both fans should operate on low speed at the lower temp set point, and both fans should operate on high speed at the higher temp set point. If you are having higher then normal temps on the highway, then your radiator is probably plugged up with road debris, because fans are turned off once the car reaches 35mph.
is 225-230 bad/normal reving at 2k not moving just parked i changed the thermostat today 180 so same as i had. i only saw fan turn on when i got to 225. i cant see the drivers fan not sure how to verify if its working unless i jack it up im guessing its hard to see if its spinning it is 111 outside right now. i just fixed my damn gas gauge showing empty it happened today
since the thermostat replaced i hit 230 in stop and go traffic one time but it went back down to 220 in like 2mins. Fans will be first to change if not the Rad. could a wire/sensor be bad to the fans ? i still need to verify if the drivers side rad fan works
so anything above 230 in stop and go traffic(or idle) would be considered a bad sign? i just never use to get this hot so im kinda on the sketchy feeling side right now i never use to hit 220
i will be doing that tomorrow after work this is my daily driver so im trying to keep it as best as i can without messing anything up. i will update tomorrow on fan status and temp changes, thanks for all the help so far
Verify it by very carefully putting you fingers down behind it.
your owners manual will tell you the operating temperature.
dont have one some stuff was missing when i bought it like one of my valve covers was messed up but ive seen on the forums some temps regarding fan operations
yikes, sorry to hear. Well you've come to the right join. Some of us are certified, not saying that I am but yeah.
but in my not so professional opinion, that seems to be to normal operating temperature.
