Need Belt Help!!
Old Dec 1, 2002 | 07:12 PM
GmasterB's Avatar
GmasterB
Default Need Belt Help!!
I need to replace the belt on my 2000 C5. I went to Checker, and they gave me a small, way too thin belt. I told the guy that wasn't even close to being right. Then I took him out to look at mine and we tried to get the numbers off of it, but no luck. Does anyone know the Dayco number of a 2000 C5 belt? Or, what the part number is of the belt that fits a 00. Thanks.
Old Dec 1, 2002 | 09:42 PM
luvinc5's Avatar
luvinc5
Default Re: Need Belt Help!! (GmasterB)
I can't answer your question directly but why not replace it with a GM serpentine belt?
Old Dec 2, 2002 | 01:04 AM
GmasterB's Avatar
GmasterB
Default Re: Need Belt Help!! (luvinc5)
Well....it's Sunday, they aren't open.
Old Dec 2, 2002 | 07:32 PM
JCR's Avatar
JCR
DAYCO #207372 with alternator clutch DAYCO #207357 (GM12561452)
Old Dec 2, 2002 | 08:07 PM
GmasterB's Avatar
GmasterB
Default Re: Need Belt Help!! (JCR)
JCR, I see according to your profile that you have a 98. I need the numbers for a 00 plz. They are different, your GM number does not match mine. I don't know what the differences are, but the numbers don't match. Does anyone have a Year 2000 Car that can help me out? Thanks... :cheers:
Old Dec 3, 2002 | 04:40 AM
C5 Frederik's Avatar
C5 Frederik
That´s what I found:
Belt, W/PMP & GEN & P/S PUMP (2025 MM LG) 97-01 # 12561501
Frederik
Old Dec 3, 2002 | 06:55 AM
rwj383's Avatar
rwj383
Default Re: Need Belt Help!! (C5 Frederik)
as far as i know the belts are the same for each year. However, i cannot explain the different GM part #'s. The a/c belt should be the same, as well. doesnt A/C come standard on the C5? you can practically pull your belt right there in the parts store parking lot then match it up. Take a ratchet w/15mm deep well with you. That's it.
Old Dec 3, 2002 | 04:59 PM
JCR's Avatar
JCR
Should be Dayco #207372 If you have the upgraded alternator(w/clutch drive) you would use Dayco 207357(GM 12561452) or Dayco (6pk2030)
Old Dec 3, 2002 | 05:11 PM
kp's Avatar
kp
Aftermarket dayco number should be 5060800, gates K060800 80" long six rib...
To Need Belt Help!!
