How to Pull Codes????
Old Sep 6, 2020 | 04:47 PM
57gman's Avatar
57gman
Default How to Pull Codes????
The proverbial SERVICE ENGINE SOON light came on today. Never seen that one before in 7 years. How do you pull codes again?????
Old Sep 6, 2020 | 04:57 PM
bc6152's Avatar
bc6152
Do a search and you'll find numerous posts...
Old Sep 6, 2020 | 09:13 PM
LstHura's Avatar
LstHura
You can enter the Diagnostic Display mode using the following procedure:
1. Turn the ignition to the "On" position but don't start the engine.
2. Press the "Reset" button on the Driver Information Center (DIC) to turn off any existing warning messages.
3. Press and hold the "Options" button.
4. While holding the "Options" button, press the "Fuel" button four times within a 10-second period.
The onboard diagnostics system will go into the "Automatic" mode, which shows each module's DTCs in a preset sequence:
1. 10 - PCM (Powertrain Control Module)
2. 28 - TCS (Traction Control System)
3. 38 - RTD (Real Time Damping. Some models do not have this option.)
4. 40 - BCM (Body Control Module)
5. 60 - IPC (Instrument Panel Cluster)
6. 80 - Radio
7. 99 - HVAC (Heater Vent-Air Conditioning)
8. A0 - LDCM (Left Door Control Module)
9. A1 - RDCM (Right Door Control Module)
10. AC - SCM (Seat Control Module)
11. B0 - RFA (Remote Function Actuation)For each module, all existing DTCs will be displayed. If no faults are present in a particular module, you'll see "No More Codes" on the IPC display.
Old Sep 7, 2020 | 05:28 PM
57gman's Avatar
57gman
Thank you, Exactly what I was looking for. Also today I reset the DIC and the SERVICE ENGINE NOW stayed off and never came back on in a 40 mile trip! Never know when I'll need this!
Old Sep 7, 2020 | 08:27 PM
LstHura's Avatar
LstHura
You are quite welcome. Glad it helped.
Old Sep 7, 2020 | 10:33 PM
Moved to C5 Tech.
Old Sep 8, 2020 | 06:00 AM
Hitman227's Avatar
Hitman227
Don't forget you can spend the money for HP Tuners, as well, if planning on tuning, or just utilizing the Scanner component (it also can modify/set and clear codes).
To How to Pull Codes????
