Steam Crossover Replacement
Old Sep 10, 2020 | 12:34 AM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
Default Steam Crossover Replacement
I see the crossover replacement lines that just go to each head without the run to the radiator, but they don’t also sell a cap to maintain pressure on the radiator side. Anyone installed this type of crossover and what’d ya do to seal the hose from the radiator? Just a bolt or something similar inserted into the hose??
clint
Old Sep 10, 2020 | 12:10 PM
mykream's Avatar
mykream
Uhh.. The steam vent lines have to go to the radiator.
Old Sep 10, 2020 | 06:05 PM
Speedy007's Avatar
Speedy007
I removed mine steam vents under the intake...?
U can block off the back ports and get some lines with fitting for the front the throttle body can be blocked off as welll...
I used these didn’t need all the parts in the line kit cross over somethings had to be cut Ect...maybe it
Old Sep 10, 2020 | 11:35 PM
Blue Blood's Avatar
Blue Blood
this hose bypasses the throttle body and radiator.
https://www.summitracing.com/parts/i...SABEgJ97vD_BwE
Old Sep 11, 2020 | 12:01 AM
Speedy007's Avatar
Speedy007
That will work for the rear of the intake but u really don’t need the braided line .. will need one fitting off the passenger side head to the radiator over flow line is it top most left line I’ll picture and show you what u will need plus a few rubber plugs ......
Besides the front blockers that came in that 169.00 kit all we used was the one last picture The 60 degree bent fitting pipe we actually didn’t use the lines at all just cut the fitting got into the stock tube and plugged up the throttle body with some rubber high heat temp caps ....
1 of these
Old Sep 11, 2020 | 12:18 AM
Speedy007's Avatar
Speedy007
You golden got the idea of wha ya need ?
Old Sep 12, 2020 | 12:54 AM
Blue Blood's Avatar
Blue Blood
Yep, thank you!
To Steam Crossover Replacement
