Fuse blows when car gets wet
Old Sep 24, 2020 | 11:49 AM
awches's Avatar
awches
Default Fuse blows when car gets wet
I had been having problems that cropped up all of a sudden of the Tail Light Fuse in the passengers compartment blowing when turning the multifunction switch to the first position for for running lights. Really all started a bit after a job I had done where the shop changed all the gaskets and seals on the engine that were leaking.
I disconnected both the front and rear harness the goes to the tail lights and all the lights on the front bumper. Still blew the fuse. But, if I would let the car set up and totally dry out for a week or so, all was good.
So, I bought it to a shop as it needed the pullies/ tensioner and belt changed on the A/C anyway and my body was not wanting to do that again.
They didn't hunt very had cept for what I had already done.
Then, at one time, when all was good and I run a floor jack on one side to get the car up high enough to get my big jack under it to check and clean the radiators. I turn on the multi switch to check it and bang, it blew the fuse. Ah Ha, Twisting the frame does it also.
So later while up on quick jacks and changing oil I started following the main harness going to the back. Saw where it was really tight at the rear of the manifold where it bolts to the exhaust pipe. So moved that to a higher place so not in a bind.
Got the car wet yesterday and when getting home, Tried it so see if the fuse would still blow. No, all good. So, this morning , up on the jacks again and some window silicone seal and a piece of saturated foam was place between the harness and the exhaust manifold.
Gonna let that all harden a day or two and going after the next rain storm to see if all is good again.
Old Oct 17, 2020 | 09:25 AM
awches's Avatar
awches
Well, a follow up on my short repair attempt. 2500 miles later and running in rain yesterday and all still works when turning on the day time driving lights . So far, my patch to protect and reseal the harness at the rear manifold bolts is still good.
