04 Z06 pre purchase questions
Before buying i had a few questions i thought the forum could help me with:
- which mods can be seen in the pics?
- any input on quality of the aftermarket intake and heads?
- given the mods how concerned should i be with valvetrain possibly still being sick? My assumption is that it is not stock but i don't know.
- what is circled in red? It is not currently connected to anything.
- what is the deal with all of the rusty bolts? Too much engine cleaning?
- car is also showing p0327 and p0332 codes when driven relatively hard. Based on forum research could this be corrosion due to over washing engine or was that only really on 2002 and prior cars?
- the engine codes concern me. Any thoughts on if a tune should fix this? Also potential that sensors are counterfeit as i believe they were recently replaced. I don't hear any knocking/ pinging and neither has current owner or his mechanic.
- other code is b0441
...follow the line back to the purge valve solenoid.
Might I suggest a vararam intake system true cold air! They have questionable fit and finish, but work the best are proven
By themselves heads cam (H/C) cars are not inherently prone to fail, they have better valvetrain after all, and the heads are not consumable, cam is good to go, the life of the motor, should be!
Yeah don;t know wtf that is, some sort of external solenoid it seems, hmph..
Sure replace the springs, good measure don't know how many of those modded miles were on the motor, if you know what I mean wink wink. I definitely would if I were you
Would be a great platform to work with, I'm envious!
Last edited by grinder11; Oct 5, 2020 at 09:52 AM. Reason: Spell and more info to add
I bet it runs well.
Those codes should be easy to fix.
I’d say the price is fair. Should you choose to put it back to stock, you can get good money for the parts that are on it now.
Ron
