2004 C5 Blue smoke
Old Oct 3, 2020 | 05:00 PM
Citybuild122's Avatar
Citybuild122
Cruising
Originally Posted by helga203
There you go. Thank you for the update. I have never seen a car that did not leak oil on the floor with a bad seal. That's why i asked or maybe i missed that. This is my experience. Some might not leak on the floor but i never seen it.
I'm going to have a leakdown test done just to have peace of mind, but it's not showing symptoms of a blown head gasket other than white smoke, but the white smoke isn't constant and pretty inconsistent. It could also just be related to the decat producing a little bit of smoke.
Old Oct 3, 2020 | 08:02 PM
Napoleon_Tanerite's Avatar
Napoleon_Tanerite
Sorry for the wrong direction advice. I missed the post where he found the seal leak. I was going from the initial posts where it seemed like it WASN'T leaking on the outside of the engine. Disregard everything I said. Glad to hear it's nowhere near as serious as I initially thought. Rear main seal is a pain just because of all the stuff you need to do to access it, but at least it's not an engine rebuild.
Old Oct 5, 2020 | 02:36 AM
Citybuild122
Cruising
No worries! I'm just glad that it's not the worst as I also assumed. I still am slightly concerned about that white smoke, even though I probably shouldn't be. Buying a new car is always scary, especially something like a heavily modified corvette. I'll definitely update everyone as soon as that leak down test gets done.
