Very odd fob predicament
Old Sep 29, 2020 | 07:06 PM
DaveOstrow's Avatar
DaveOstrow
Default Very odd fob predicament
I have an 04 Coupe have an odd predicament going on. When I bought it a couple of weeks ago had one fob they couldnt get a second fob program to it. they gave me a second fob for me to try programming cuz I'm pretty handy with stuff.
Oddly,
I can get either fob programmed as the first fob, and neither fob will program as the second fob. So basically both fobs work but can't get both of them program simultaneously, regardless of which one's in first or second position. I've read through the forms I'm not sure what to do here. I'm hoping somebody has an idea. Thanks in advance David
Old Sep 29, 2020 | 08:12 PM
OregonDan's Avatar
OregonDan
Are you trying to get them to function as one and two for the memory seats & stuff? Or some other purpose?
Old Sep 29, 2020 | 08:18 PM
DaveOstrow's Avatar
DaveOstrow
I want 2 functioning gobs. One for me and one for wife so whoever uses has a functioning fob
DaveOstrow's Avatar
DaveOstrow
Old Sep 29, 2020 | 08:21 PM
OregonDan's Avatar
OregonDan
And you're using the fob training mode of the DIC?
Old Sep 29, 2020 | 08:22 PM
DaveOstrow's Avatar
DaveOstrow
Yes sir. As I said using the dic I can get either fob on fob1 position bit cant get either as the second to program
Old Sep 30, 2020 | 06:36 AM
Ron C!'s Avatar
Ron C!
Do you have a #1 and a #2 fob? Numbers are on the back, not sure if you can or cannot program 2 of the same number? Just a thought.
Old Sep 30, 2020 | 06:43 AM
Autotragic's Avatar
Autotragic
Pretty sure those numbers are just for reference on the factory fobs, I bought a pair of matching red fobs on Amazon and both programmed just fine. Also The OP should try new fobs as they are pretty cheap I think my red ones were less than $20 for the pair.
Old Sep 30, 2020 | 07:19 AM
DaveOstrow's Avatar
DaveOstrow
Thanks all. So the rub of this is that neither fob is oem. Both were give to us by the used car dealer. One was programmed. They said they tried several other fobs and non would program as the second fob. So they had this issue. The car will accept either one as the forst fob, but neither one as the second fob. When either one is programmed as the first fob it works perfectly, and regardless of which one I try second it will not program. Guess I could buy a pair of fobs and report back. So we know the batteries on the fobs work and the car battery is new. Just seems like the software is whacked. Any other ideas.
Old Sep 30, 2020 | 08:24 AM
Sunwarrior's Avatar
Sunwarrior
Clear all the key fobs out of the car and start fresh. Max per car is 3. Someone my have 2 slots already taken?
Old Sep 30, 2020 | 08:29 AM
DaveOstrow's Avatar
DaveOstrow
Are you saying have both fobs physically outside of car, put the key in and start programming then put fobs in car? Is there a way to clear the fobs registered out of memory in the cars memory?
Old Sep 30, 2020 | 09:37 AM
Sunwarrior's Avatar
Sunwarrior
When you first get into key fob setup, push Reset button on DIC. It will erase all fobs in memory, then you start fresh relearning your 2 key fobs.
Old Sep 30, 2020 | 09:42 AM
DaveOstrow's Avatar
DaveOstrow
Thank you for the clarification. I did that several times. Only 1 will program, either one, but only 1.. The second will not no matter which one I do first.. So odd.
Old Sep 30, 2020 | 10:05 AM
Sunwarrior's Avatar
Sunwarrior
I don't know if it could be checked with a Tech II unit? May someone with one will post a reply. Would it be possible to change it from 3 key fobs down to only 1 key fob? See if you can get it over to Tech forum vs general.
Old Sep 30, 2020 | 10:08 AM
DaveOstrow's Avatar
DaveOstrow
Ok. Thanks for yiur help.
Sunwarrior's Avatar
Sunwarrior
I don't know if it could be checked or changed with a Tech II unit? May someone with one will post a reply. My question is would it be possible to change it from 3 key fobs down to only 1 key fob? See if you can get it over to Tech forum vs general.
Old Sep 30, 2020 | 11:49 PM
Moved to C5 Tech.
To Very odd fob predicament
Old Oct 1, 2020 | 02:47 AM
DaveOstrow's Avatar
DaveOstrow
Moved
Old Oct 1, 2020 | 01:54 PM
DA1984VETTE's Avatar
DA1984VETTE
I have never used the programming on my fobs thru the dic. I have always held the lock/unlock buttons till the car beeped and my fobs have always worked using this method. I have a 98 don't know if that makes a difference or not, but is worth a try.
Old Oct 1, 2020 | 01:57 PM
DaveOstrow's Avatar
DaveOstrow
Thank you. I did try that. No joy.
