Gutted Interior Now Electrical Issues
Need some help here. I recently gutted the interior of my 2002 ZO6 for a roll cage to be installed. Its a track only car. I had no issues before I removed the interior. All has been removed - airbags, hvac, radio, etc. Everything other than the ECBM and the Yaw sensor. I'm having service active handling, service abs and service traction control messages. I have checked all the fuses. I have disconnected the battery for hours to reset. I have checked grounds that I know of to make sure they are clean. Car has LMC5 installed and I have not had any issues before or after install. I'm now getting remove key for 10 secs. Car is usually started and running when it happens. I get codes C1282 and c1243. No others. I have of course looked through other posts, but that could take days as these are common messages. I just believe mine is 100% an electrical issue due to stripping the car. Please let me know if you have any insight. Thanks in advance.
I would check that yaw sensor connector and make sure that the female pins in the harness connector are not all spread apart. and making a **** poor connection.
Bill
Thanks for the reply and thanks for all the info you have on the forum. I spent a ton of time reading before posting.
I have cleaned all the grounds twice. I will need to figure our how to cycle the pump this weekend. Can I just rip it down the road and hit the brakes? I'm into the ABS all the time on the track. The motor gets used often. I have been trying to tackle the yaw sensor issue first as I have done that before when I installed aftermarket seat. All the wiring looks fine and nothing has changed since a few weeks ago when all was fine.
I am concerned the BCM is the issue. Its just very odd to not have any codes a week ago and after the interior removal and cage install I have multiple. I fear it could have been damaged when the interior was removed. There was some water from the HVAC removal in the car. Battery was disconnected and I didn't think it got on the BCM. But now I'm concerned.
If I wanted to have it rebuilt what is the best path? Is there an ABSFixer type company for the BCM? I would rather have this one rebuilt vs installing a new one and having to have it programmed. Thanks again Fraser
im now able to get the 1243 code to go away for a few minutes, but as soon as I start moving it comes back. Before I would clear the codes and then start it up and instantly got the codes. Even if I cleared them while running they would come back immediately. So certainly better but not solved. What is the next step? Bleed the system?
