air in coolant or clog?
Old Oct 3, 2020 | 05:40 PM
Stroker87's Avatar
Stroker87
Default air in coolant or clog?
so....
i finally got the new engine in my car, having an issue with it getting hot while idling but soon as i start to rev it or drive temps drop? i've seen 240's just while idling if i hold rpms up a little 1500-2000 temps drop. hose going to the radiator i can keep my hands on them (only warm) heater core hoses get hot cant touch them, i bleed the steam port, let it idle with cap off a few times, did the hole 3000 rpms thing a few times. thinking maybe the radiator is clogged?
im lost on where to go from here
Old Oct 3, 2020 | 07:58 PM
Napoleon_Tanerite's Avatar
Napoleon_Tanerite
What engine, what radiator? I've got a similar thing with my LS3 and Dewitt's radiator. It will get up to about 240 or so on initial warmup, then the temp will drop rapidly and stay around 200 all day long. After your temp drops initially will it climb back up?
Old Oct 3, 2020 | 08:32 PM
Stroker87's Avatar
Stroker87
ls3 base 416, long as i rev the engine they will come down or if driving. soon as i stop they start climbing? thinking maybe the thermostat got stuck closed?
Old Oct 3, 2020 | 08:39 PM
Napoleon_Tanerite
You using the factory C5 radiator and fans?
Old Oct 3, 2020 | 08:40 PM
mmartinez's Avatar
mmartinez
What about your fans are they turning on?
Old Oct 3, 2020 | 10:17 PM
Stroker87's Avatar
Stroker87
Using stock fans and radiator, the fans are working correctly low/hi and are starting at 195 low 205 hi
going to swap the thermostat today see if thats it, if not probably pickup a ECP aluminum radiator
Old Oct 4, 2020 | 10:22 AM
mmartinez's Avatar
mmartinez
Sometimes it's something as simple as installing the thermostat incorrectly, with the wrong side facing the engine block, don't ask me how I know this. lol
Old Oct 4, 2020 | 10:37 AM
Stroker87's Avatar
Stroker87
ha! i've complicated some very simple things in my life i know the feeling, the stat is in right i never opened the housing when i pulled it off the old engine
if its not the thermostat witch ill know in a few hours then has to be the radiator at this point im pretty sure its not air in the system
Old Oct 4, 2020 | 07:20 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Have you tried to clean the radiator and the AC Condenser?? There is a 1" space between them and that space can collect a LOT of trash/sand/dirt, grass and stuff... I use a garden gose and back flush the radiator. You would be amazed on the sand and dirt that comes out. DO NOT use a pressure washer.
Bill
Old Oct 4, 2020 | 08:47 PM
3sACROWD's Avatar
3sACROWD
The fact that your temps lower with increased RPM leads me to believe it is not your radiator. It sounds like an air bubble or maybe a partially functioning thermostat.
Old Oct 5, 2020 | 02:04 PM
Stroker87's Avatar
Stroker87
I drained the radiator then installed a 187* thermostat filled it up bled the system and now got rock solid temps idling between 198 & 201 let it idle for 45 minutes then drove it so it looks like its all good now
thanks for the input!
Bill
yeah i did that about 3 years go (cars been sitting since the old engine let go) but that season i pulled the radiator out and washed it down and it was dirty!
To air in coolant or clog?
