Yet another clutch problem.
Old Feb 21, 2021 | 03:41 AM
Lord_TyranusVulgaris's Avatar
Originally Posted by helga203
Dont see why not but did i miss read about Pilot bearing not on your list???
Im glad you asked! As much as I can tell 04905 kit includes pilot bearing, but since I was not 100% sure I ordered CT1078 separately. Which is supposedly original GM pilot.
Could someone be so kind and help me out with the engine side seal part numbers?
Old Feb 21, 2021 | 10:29 AM
helga203's Avatar
helga203
R u doing the work yourself?? Taking off that bellhouse PITA. Big time, if your doing it for the first time and you have to have the right tools. How many miles?? This is JMO, I,ve done many of my friends clutches and if its not leaking the seal is good. I'm just saying.
https://www.corvetteforum.com/forums...main-seal.html Somthing to think about. If your having it done it might be in the qoute so then go for it. Bill curlly does not take shortcuts.
Old Feb 21, 2021 | 11:20 AM
Chogan835's Avatar
Chogan835
GM 89060436
GM 12639249
The little extra work isn’t that bad. Your clutch should last 75-100k miles. Personally, I would never want to be in there twice over that period. That’s why I did all the seals. Not to mention rear main seal and trans/diff leaks are extremely common with these cars.
Old Feb 21, 2021 | 01:44 PM
78k miles.
I was planning on doing it myself, since i have been sitting on my *** for almost a year now. But out of nowhere some work landed on me and now i have a horrible choice of giving it to someone or doing it on weekends. Both options suck... Probably, very reluctantly i'll have to use someone.
Regarding tool as much as i understand the only special tool that i would need is a big *** torque tube snap ring pliers?
Old Feb 21, 2021 | 01:49 PM
Originally Posted by Chogan835
GM 89060436
GM 12639249
Your a gift from the Gods!!
I would preferer not to revisit this topic either
I dont suppose you would know part.nr for rear main seal?
Old Feb 21, 2021 | 02:47 PM
helga203's Avatar
helga203
78k miles.
Different size Extensions and swivels which can easily be bought anywhere just have to figure out the right sizes or u will not get that bellhousing off. Some dont have problems and a lot do like myself that's why i converted to Buddhism.
Old Feb 21, 2021 | 02:53 PM
Chogan835's Avatar
Chogan835
those parts numbers are for rear main and rear cover seal.
Old Feb 21, 2021 | 03:44 PM
Did i write rear main seal? What i actually meant is if there is something on rear diff's side.
Old Feb 21, 2021 | 03:45 PM
Sounds practical! I'll have to look in to it
Old Feb 22, 2021 | 02:17 PM
I wanted to thank everyone who took they're time to answer my silly questions. You were very helpful. Thank you!
