Noticed something interesting while logging monday....
Old Dec 3, 2002 | 04:47 PM
Phil97SVT's Avatar
Phil97SVT
Default Noticed something interesting while logging monday....
Well to keep it short and simple I went out and drove around for 20 minutes to see where my LTFT's ended up. Well scrolling down the options I noticed the IAT was reading 86 degrees but the outside temp was near 40 degrees. Sound like I need to install the vararam intake to get the intake temps down to make some more hp.
Phillip :D
Old Dec 3, 2002 | 05:33 PM
C5Noir's Avatar
C5Noir
Default Re: Noticed something interesting while logging monday.... (Phil97SVT)
The V-Ram rocks man, you'll love it.
Old Dec 3, 2002 | 11:16 PM
chuckster's Avatar
chuckster
Phillip :D
The IAT temp always goes up if you are sitting at a light...If you are driving in 40 degree for at least a mile or so and it still shows up that hot..You have a bad sensor...It should cool down once you start moving...
A way to test the circuit..is to put a 4.7k ohm resistor in the IAT socket.. Autotap should read 57 degrees..
My IAT usually reads 10 degrees higher than ambient temp shown on the A/C
To Noticed something interesting while logging monday....
