P1860 Code
Old Oct 11, 2020 | 11:26 AM
KEARNEYN's Avatar
KEARNEYN
Default P1860 Code
Hello I own a 99 corvette and for several months I keep receiving code P1860. I have done reasearch to discover that this code is indicating an error with the Torque Converter Clutch Pulse Width Modulation Solenoid Valve. Since the error is indicating a short somewhere in the circuit, I have checked many engine grounds and electrical connections. Specifically G120 that the PCM should use to ground the solenoid but the code keeps returning. I have even taken the car to a transmission shop to replace the solenoid but the code keeps returning. Any help or knowledge in fixing this code would be greatly appreciated.
Thanks!
Old Oct 11, 2020 | 10:44 PM
docrocket1967's Avatar
docrocket1967
Are you running an aftermarket torque converter and is there any difference in stall speed?
Old Oct 11, 2020 | 10:50 PM
KEARNEYN's Avatar
KEARNEYN
I am running a stock torque converter. Car only has 28K miles.
Old Oct 17, 2020 | 09:20 AM
KEARNEYN's Avatar
KEARNEYN
I am still receiving the P1860 code. Any other ideas would be greatly appreciated.
Old Oct 19, 2020 | 12:58 AM
jim993's Avatar
jim993
I have no clue but check this:
https://www.engine-codes.com/p1860_chevrolet.html
I notice that the ignition circuit is mentioned and I am wondering if the ignition switch might be deteriorating, causing the DTC. Difficult to diagnose, but if the car exhibits other symptoms, that could narrow the diagnosis.
"The solenoid receives ignition voltage through circuit 239."
Any other, seemingly unrelated, symptoms?
Old Oct 19, 2020 | 03:03 PM
Moved to C5 Tech.
Old Oct 19, 2020 | 05:52 PM
69's Avatar
69
Cruise-In VI Veteran
Havr a look at my posting in this thread.
https://www.corvetteforum.com/forums...1860-code.html
Old Oct 19, 2020 | 09:59 PM
sloopdawg's Avatar
sloopdawg
a new ignition switch cured quite a few issues I was having
To P1860 Code
