lifting the car
Old Dec 4, 2002 | 05:33 AM
eaa1964's Avatar
eaa1964
Default lifting the car
It seems a great deal of you work on your car...perhaps you would share your methods for lifting the front end up 14-16 inches off the ground-SAFELY. I would like to install air vents in the fog lamp area.
I do not have acces to a real lift.
[Modified by eaa1964, 10:34 AM 12/4/2002]
Old Dec 4, 2002 | 05:41 AM
Ricksc5's Avatar
Ricksc5
Default Re: lifting the car (eaa1964)
Rhino makes plastic drive up ramps that are low enough to go under the C5 nose and get the car up almost one foot. You can get them at walmart for around $40.
Old Dec 4, 2002 | 06:49 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Default Re: lifting the car (Ricksc5)
:iagree: I have a set for when I don't need to put it on the lift.
$29.99 at Pep Boys, Advance auto, etc...
Here is what they look like
To lifting the car
