Which timing chain with ASP Pullie
Old Dec 4, 2002 | 08:46 AM
kromberg's Avatar
kromberg
Default Which timing chain with ASP Pullie
I am getting ready to swap out cams and I am planning on changing the timing chain also. I have the ASP under drive pullie and I have heard that it requires machining to use with the SLP double roller. What timing chain will work with the ASP pullie without modification? TIA.
Keith
Old Dec 4, 2002 | 09:14 AM
Patches's Avatar
Patches
Default Re: Which timing chain with ASP Pullie (kromberg)
I'm using the RollMaster dual roller with the ASP pulley that I modified. Modding the pulley is a simple job for any machine shop. The machinist must indicate off the hub to get an accurate cut, though, due to the construction of the pulley.
RollMaster also makes a single true roller that's even cheaper than the double. My double cost me less than $80 shipped from Down Under in just a week from order date. I believe SDPC sells them as well. Katech and others sell upgraded single chains also. Click on images to enlarge.
Single chains
My Rollmaster
The dimension A on the pulley has been increased by .125"
:thumbs:
[Modified by Patches, 6:49 PM 12/4/2002]
