Anoter New tire & TPMS problem
I changed out the run flats to new non-run flats, and also new tpms. This was done by a tire shop with many years experience. Everything was working fine, left the tire shop , drove a couple miles, in the city and BAM! a message showed up," LR tire is flat" Do Not Exceed 55mph!, I turned around went back to the tire shop, they checked and relearned the TPMS, with their laptop. OK! started back home, traveled approx 20 miles. Pulled into my garage, and the same message showed up again. Thinking that it needed to reset on message center, went thru cleared codes, and reset. Still the same message, so I thought to my self to disconnect battery for a few minutes. Re connected battery, message was gone , everything kool. Drove about 2 miles again , message right back, so went back to the tire shop, bc i dont own the softwear, told them the problem, they redone the laptop thing.....got everything back to normal, started back home , same message, but with a twist.....LR & RF are now flat with 0 psi Do Not exceed 55 mph! Mind you none of this was happening before changing out with new tires and sensors. I hope you fellers can help or lead me in the right direction.
Thanks in advanvce for all your help in the past, now and in the future!
Max
my 2 cents
TCFS
I would see what sensors they installed. If it's some no name, I would swap them out for Schraders. There are also date codes on the sensors so you can tell you didn't get a 6 year old shelf sitter.
Like Ed Ramberger recommended, If they cant get them to function properly, return them and install the GM OEM Schrader sensors.
Bill
See i never had this problem before now. I had a 67 Air coupe foe the last 20 sum yrs. This is a new journey for me and technology. CF has always been here for info and solutions to problems. So thanks again, and if you ever need me to help you guys, i'll give it old Marine Corp try.
Max a.k.a. aclassicnut
I did order a relearn tool with the wheel sensors, and even changed out the battery in the tool. But did not use it because the tire shop used their laptop to relearn the tires . So what i'm thinking is go back to the tire shop, work a deal and replce the sensors with the ones that were taking them oyy
just my 2cents to clarify.
TCFS
https://www.corvetteforum.com/forums...-chime-in.html
Cheers,
I really have repect to all on this forum.......everyone is so heplful, the knowledge and experience 1st class!
Recpectively ,
Max
Recpectively ,
Max
Internet #203613197
Model #96604
Store SKU #101931
as Ed is writing, when one fail, the others will soon since their battery have seen the same amount of working hours, therefore we tend to change a set of 4... but this is not mandatory. For your information also, the TPMS sensor are activated only when the wheel is spinning, therefore, more than the time, it is the mileage that have a impact on the sensor battery life.
mine started to fail around 110kmiles on my 2000.
my 5cents.
TCFS
I brag on you guys all the time,in conservation with friends, relatives, etc. The knowledge and of course experience that this forum (C2-C5)has is so informed . It can't be beat! I have seen on the internet that there techs that will charge $$$$$$ for answers to problems that should be given freely. And there be some on these forums, but haven't run accross any as of yet. What I have found is the willingness to help fellow owners with tech problems. I for one an weak in electronics, so I try to read as much i can understand. I'm more mechanically inclined than elcectronics. So a humble thank you to all. Everyone has been so heplful and advice is very well considered and taken!!
Hope this doesn't sound too corny
Max
Max
