Water pumps on C5's
Old Dec 4, 2002 | 03:01 PM
Pewter1's Avatar
Pewter1
Default Water pumps on C5's
Has anyone had any problems with water pumps on their C5's? I was doing my FLP header install yesterday, and noticed some orangish fluid on the bottom of my motor and investigating farther looked like it was coming from the water pump area. Anyone had this problem, and if so what was the cost of the fix? :confused:
Old Dec 4, 2002 | 03:17 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Re: Water pumps on C5's (Pewter1)
I would guess $500. But that's just a guess.
Old Dec 4, 2002 | 05:48 PM
gonbad's Avatar
gonbad
I have over 91,000 miles on my 98 and it just started leaking about a month ago. It didn't start until I flushed the system and put in fresh coolant. I am thinking the old coolant was thick and nasty and hiding the leak. I am waiting for school to get out for the winter break and then I will tear it out and probably replace all the idler/tension pulleyes as well. Something is screeching and it is driving me nuts.
Old Dec 4, 2002 | 05:53 PM
Jeff Jeff's Avatar
Jeff Jeff
Default Re: Water pumps on C5's (gonbad)
Mine went out at 40k miles. It started with a slight coolant smell, then began to leak after getting on it one day. The install was about 500 with a new belt at the dealer under ext. warranty.
Old Dec 4, 2002 | 08:17 PM
jmX's Avatar
jmX
Default Re: Water pumps on C5's (Jeff Jeff)
Probably just bad water pump gaskets. They cost about $5 for 2. The whole water pump comes off with just 6 10mm bolts being removed, and is something you can do in under an hour. If you aren't under warranty, start by checking those gaskets.
Old Dec 4, 2002 | 08:48 PM
Z.06's Avatar
Z.06
I have a 2001 Z06 which started making a whistling noise when fully warm at about 6000 miles. On the fourth trip to the dealer they tracked the noise to the water pump. It was replaced under warranty. They never said whether the noise came from the seal or the bearing or what. I was just glad to get the bad pump replaced rather than eventually having it fail out on the road somewhere.
Old Dec 4, 2002 | 10:30 PM
Pewter1's Avatar
Pewter1
Default Re: Water pumps on C5's (Z.06)
I'll be checking those gaskets......I have notnoticed any noise or whinning! Thanks guys! :cheers:
Old Dec 4, 2002 | 11:15 PM
alanh's Avatar
alanh
I had to replace my pump due to metal porsity. It first started leaking at about 40,000 mi and I was able to stop it for a while with GM stop leak for metal porsity. It started leaking again at about 60,000 and I got tired of the small leak and replaced it. When you got the conditions right you could watch the antifreeze come right through the bottom and form drops on the pump.
Old Dec 5, 2002 | 11:56 AM
ddawson's Avatar
ddawson
Default Re: Water pumps on C5's (alanh)
I replaced mine a last month. Its pretty easy to do with standard tools. Take the Throttle body off to give your self more room.
Also my leak wasn't coming from the water pump :(
My leak was from the bottom TB coolant line that feeds the heads. I found this of course after I replaced the WP.
Old Dec 5, 2002 | 12:30 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I had my pump go out at 22,000 miles. It was replaced under warranty. :)
vetterdstr :cheers:
Old Dec 7, 2002 | 01:50 AM
AZCARGASM's Avatar
AZCARGASM
Maybe this is really a new thread, but has anyone expeienced the coolant turning to gel? If you stay with the GM coolant, I recommend you change more often. Some people have experienced gelling with DX coolant. After warranty I will probably switch to Honda coolant. Honda has been making aluminum engine/heads longer than anyone (I have two) and there coolant is among the best I've seen. Use honda coolant and water wetter and I think you will be happy. At least you won't see your coolant turning to gel.
JMHO AzCargasm im North Scottsdale. :smash: :smash: :cool:
Old Dec 14, 2002 | 03:45 PM
bgood's Avatar
bgood
Cruise-In IV Veteran
St. Jude Contributor
My water pump went out on me this week as well (@ 77k miles). This is also after a coolant flush that was done about 2 months ago. Looks like once you put some new coolant in the car the crud left in the radiator eventually breaks away and moves around a little easier.
The water pump replacment along with replacing both belts and adding additional coolant wound up being around $468.
Old Dec 16, 2002 | 12:21 PM
Bling Bling's Avatar
Bling Bling
Default Re: Water pumps on C5's (bgood)
Mine went out around 50K. It started making a squeking noise and some fluid leaked.
To Water pumps on C5's
