Ac comprssor
Old Nov 5, 2020 | 10:32 AM
1997 C5's Avatar
1997 C5
Default Ac comprssor
My 97 C5 A/T ac compressor is going bad, leaking dye/freon @ clutch seam. Questions is will 97-04 C5 ac compressor fit my C5?
I'm thinking of finding a used one. New one I saw in on Amazon one for $225.00( I think this is bosch brand suppose to be OEM part?) and OEM around $325.00
Old Nov 5, 2020 | 09:04 PM
JWM's Avatar
JWM
Bosch is not oem. Check Rock Auto for suitable replacement. Oem is a seven piston compressor. Some aftermarket units are five. Either will work
Old Nov 5, 2020 | 11:28 PM
bookyoh's Avatar
bookyoh
97 - 04 all use the same Delphi 7 cylinder variable displacement compressor.
I suggest you spend the money on the Delphi service compressor if you are going to all the work to replace it. Seems like they are going for about $250.
You described it as leaking at the clutch seam so I am guessing you see dye and oil being slung out by the pulley. If that is the case, there is a lip seal which is accessible by removing the clutch and it is servicable.
Old Nov 6, 2020 | 04:38 PM
grinder11's Avatar
grinder11
A 4 Seasons V7 brand Compressor in Michigan goes for $335.00 tax included. I've heard good things, and nothing bad about them, yet......
Old Nov 6, 2020 | 06:45 PM
bookyoh's Avatar
bookyoh
I can’t think of a good reason to buy something other than the Delphi OEM service compressor. It’s about $250 on Amazon. Four Seasons and any other after market has to reverse engineer their models.
Old Nov 7, 2020 | 07:22 AM
grinder11's Avatar
grinder11
I tend to agree on OEM parts, but not always. I'm still running my original compressor, and its 20 years old. Reverse engineering can be a good thing, as some flaws may be present in original designs. The 4 seasons compressor is a good compressor. So is Sanden. If OEM designs are better, aftermarket oil pressure sensors wouldn't be lasting as long as, or longer, than OEM sensors. All 3 compressors are good options, in my opinion. There's also counterfeit brands out there, and Amazon has been accused of, unintentionally, peddling some of them. NGK spark plugs come to mind. As expensive as this item is, along with it being labor intensive to replace, I believe I'd buy the item locally, but thats just me. Honestly, when I need a new one, it will be either an OEM, 4 seasons, or a Sanden, whoever has the best deal at the time.....
Last edited by grinder11; Nov 7, 2020 at 07:32 AM. Reason: Spell and more info to add
To Ac comprssor
