Horn stopped working
Old Nov 13, 2020 | 04:51 PM
NC98C5's Avatar
NC98C5
Default Horn stopped working
I replaced the horn membrane 2 years ago and the horn stopped working again. I thought it might be the multi-purpose switch ( was having problems with right turn signal not lighting sometimes) so just replaced it. Still no luck. Tried switching relays and no luck. I jumped the horn and it works and works when I hit the fob. I would say that it is the membrane again, but when I connect a test light to the relay terminal, the battery positive and push the horn button it lights up. I assume that means the membrane is working and grounding like it should. Now it is hit and miss on lighting up, but I would think the horn would sound intermittently. Any ideas? I hate to replace the membrane and still no horn.
Thanks for any help!!
Old Nov 13, 2020 | 08:24 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If the horn works with the FOB 90% of the circuit is good...right now I too have an inop horn but haven’t had time to diagnose it but I will in the next few days or week...mine also works with the FOB so I’m thinking MAYBE horn membrane but I don’t guess until I diagnose the circuit...maybe I’ll do a YouTube video...haven’t done one in a while.
Old Nov 15, 2020 | 12:23 PM
NC98C5's Avatar
NC98C5
OK, I tested the #5 pin on the C209 connector under the steering column and if I ground it manually the horn honks. So if my logic is correct that means the circuit is good but the button isn't connecting the ground. Think I am going to go ahead order a horn membrane. Thoughts?
Old Nov 15, 2020 | 01:50 PM
NC98C5's Avatar
NC98C5
FIXED! I already had the column apart so I went ahead and took the wheel apart. I removed the membrane and tested with a multimeter. Checked out fine. connected with clips to the wiring and horn worked when applying pressure to membrane. I put it back together and works. I am pretty sure the issue was the power wire to the cancel cam was loose. Glad I didn't order the membrane.
Here are the links to the reference that helped me disassemble and test the horn membrane. Great write ups.
https://www.corvetteforum.com/forums...brane-fix.html
https://tech.corvettecentral.com/201...rn-switch-fix/
Old Nov 20, 2020 | 10:28 AM
C5 Diag's Avatar
C5 Diag
Well today I finally got around to looking at my inop horn. Horn membrane had continuity with DVOM
when depressed..looked at the power wire and the end had a little oxidation...a little emery cloth and some Stabilant 122 and all is good !!
Old Nov 20, 2020 | 05:01 PM
Smoken1's Avatar
Smoken1
Ineresting that it works on horn contacts but,not other contacts....
Old Nov 20, 2020 | 05:12 PM
C5 Diag's Avatar
C5 Diag
That what works ?????????
Old Nov 20, 2020 | 05:29 PM
Smoken1's Avatar
Smoken1
Emery cloth
Old Nov 20, 2020 | 06:06 PM
C5 Diag's Avatar
C5 Diag
Emery cloth
Emery cloth worked fine just to get rid of “minor” oxidation...I wouldn’t use it to clean the contacts on an ignition switch mind you...I would just replace it !!
To Horn stopped working
