Tpms
Old Nov 14, 2020 | 06:25 AM
4show's Avatar
4show
Default Tpms
I have a 2000 z51 110k miles. Replacing tires with Michellins pilot as3+zp. What can done if horn doesn’t work while setting up sensors?
Old Nov 14, 2020 | 10:57 AM
Argus21's Avatar
Argus21
Mine worked after I tried the procedure with the engine idling. TPMS also likes to torment us if the battery has low voltage.
Old Nov 14, 2020 | 11:56 AM
4show's Avatar
4show
How can I know if the tire is syncing when the horn doesn’t work? I just realized that my horn is inoperable prior to set-up.
Old Nov 14, 2020 | 12:09 PM
Argus21's Avatar
Argus21
The sequence for teaching is LF, RF,RR and LR. If the TPMS display on the DIC for the tire you are working on does not progress to the next tire after teaching with the magnet, then the teaching has not registered. The readout of what tire you are on is on the DIC.
Old Nov 14, 2020 | 12:45 PM
4show's Avatar
4show
Ok, I see. Thanks very much! Once again it show to be a member of this forum. I salute you all.
Old Nov 19, 2020 | 11:07 AM
4show's Avatar
4show
After a few attempts and a few more magnets, it finally worked. Thanks all for your help, I will be back asking more questions in the near future. ✊🏼
Old Nov 19, 2020 | 11:32 AM
grinder11's Avatar
grinder11
I hope this post is easy to read,, and helpful. I worked for years in skilled trades. About 40 years ago, OEMs started installing powerful magnets in the transmission oil pans. Many pans actually had/have a "dimple" on the bottom of the pan, which the circular magnets would locate on. These magnets are shaped like a mini donut-About 1-1/2" outside diameter, with about a 1/2" hole in it, and maybe a 1/4" thick. They fit right over the TPMS stem, and are powerful. GREAT for programming the TPMS. I got mine from the OEMs while we were building transmission test stands for them. Any trans repair shop should have all you want to take, probably free!!!
Old Nov 22, 2020 | 12:22 PM
The Zoob's Avatar
The Zoob
Seems I read here that the sensors can be learned before mounting them..
To Tpms
