Code P0101 serious knocking sound after major modifications
Old Dec 5, 2002 | 11:57 PM
Naylin's Avatar
Naylin
Default Code P0101 serious knocking sound after major modifications
Have had the following modifications done. Done about 3000km. Suddenly today, car felt "rough" whilst driving when reaching 3000revs. I drove another 50km before needing to slow down. Idling extremely rough. threatening to switch off. Taking into a tech 2 scanner. Cylinders 3,5,6,7 and 8 weak. tech scanner found code P0101. Told it is a problem with the cam and more major work needs doing. Am i in trouble??
Donaldson Blackwing Intake System with cold air intake
Powerduct
Belanger Headers
X-pipe Corsa or Bassani
Corse Exhaust system
LS 6 manifold with accessories
Katech Stage 2 Head and Cam package
Underdrive Pulley with belt
3.42 Gears
TC sy3500
NGK PLugs and GM hotwires
Thermostat Fan and fan controller
[Modified by Naylin, 11:16 AM 12/6/2002]
Old Dec 6, 2002 | 02:28 AM
benelliwang's Avatar
benelliwang
Default Re: Code P0101 serious knocking sound after major modifications (Naylin)
"P0101 Mass Air Flow (MAF) System performance -B"
Check your MAF first. Also, my friend had a bad IAT sensor wire that had similiar symptons.
Old Dec 6, 2002 | 05:22 PM
Naylin's Avatar
Naylin
Default Re: Code P0101 serious knocking sound after major modifications (benelliwang)
The guys that service my car live about 120 km away, Do you think I am safe to drive the car with this??
Old Dec 6, 2002 | 06:08 PM
benelliwang
Can't tell you man, it could be a mojor problem and driving it further may be bad to the engine.
However, my friend drove his car like crazy even with the engine all screwed up. :lol: And there was no problems.
Why don't you check the electric connection to the MAF and IAT first? It could be just a loose wire or leaky air tube?
Old Dec 6, 2002 | 08:36 PM
Naylin's Avatar
Naylin
I'm a total ignoramus here. so where exactly do i look for the MAF and IAt connections.. sorry, I know next to nothing
Old Dec 6, 2002 | 10:32 PM
alc2001's Avatar
alc2001
Sent you an email.
Old Dec 11, 2002 | 07:28 PM
Naylin's Avatar
Naylin
Default Re: Code P0101 serious knocking sound after major modifications (alc2001)
Mechanics have been unable to find the problem. Diagnostic code P0101 keeps coming up. Placed on dyno: flattens out after 2500 revs and no loss of oil pressure so unlikely to be the cams.. knocking noise is at idle and up to about 1000 revs then evens out and comes back above 3000 revs... Any help needed please
Old Dec 12, 2002 | 06:36 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Not sure what your knocking noise sounds like... Problem sounds sort of like a vacuum leak to me except that you describe the knocking as serious. Is is slow and "thud like"? Fast and "clicking"? Something else?
Another thing that could potentially result in your P0101 is your PCM tuning if the MAF table is wacked out. I doubt that's the case here since the problem didn't show up till well after your mods.
Is that the only code set? Were they able to get the freeze frame data for it (so you could see the conditions under which it set)?
I owe you an email. :cheers:
Old Dec 13, 2002 | 02:46 PM
Naylin's Avatar
Naylin
Default Re: Code P0101 serious knocking sound after major modifications (ToplessTexan)
the mechanics have found broken valve springs
need to get some to suit the new heads
will contact Nate
Old Dec 13, 2002 | 07:38 PM
ToplessTexan
:( Yes, that would do it. Didn't your heads come with springs matched to your cam?
Old Dec 13, 2002 | 08:14 PM
Naylin's Avatar
Naylin
yep they did, but i understand that Katech have changed the springs they were using since then.probably because there was a problem....With all the other modifications I did get 294 KW at the rear wheels on the dyno. Was that too much for the valve springs... mostly daily driving although I do get up to about 220km/h regularly.
Are you still coming to NZ and are you keen to catch up
[Modified by Naylin, 11:10 AM 12/14/2002]
To Code P0101 serious knocking sound after major modifications
