New TPMS Sensors
Old Nov 22, 2020 | 03:16 PM
rob-cyn's Avatar
rob-cyn
Default New TPMS Sensors
Had these at home and put them on some rims I just put onto my car. I looked at the listing and it said they are compatible for my 2000 FRC but I can not get them to program with a magnet so now I am wondering if I need a different magnet or these sensors aren't the right ones.
Thanks in advance
https://www.ebay.com/itm/4pcs-TPMS-T...53.m2749.l2649
Old Nov 22, 2020 | 03:25 PM
jamieo's Avatar
jamieo
Those have the same part # as my 2008.Mine program with a tool instead of a magnet.
Old Nov 22, 2020 | 03:41 PM
rob-cyn's Avatar
rob-cyn
Ah ok, I was looking at those on line, they arent very expensive so I will pick one up
Old Nov 22, 2020 | 03:48 PM
jamieo's Avatar
jamieo
I think I payed about $10 for mine on Ebay.
Old Nov 22, 2020 | 03:49 PM
rob-cyn's Avatar
rob-cyn
Like this one ? I can get cheaper but shipping from China
https://www.ebay.com/itm/EL-50448-OE....c100005.m1851
Old Nov 22, 2020 | 03:55 PM
jamieo's Avatar
jamieo
EL50448 TPMS Reset Activation Tool Relearn Auto Tire Pressure Sensor For GM Car | eBay
Old Nov 22, 2020 | 03:58 PM
rob-cyn's Avatar
rob-cyn
Cool thanks so much
Old Nov 22, 2020 | 04:03 PM
jamieo's Avatar
jamieo
No problem
Old Nov 24, 2020 | 11:22 AM
grinder11's Avatar
grinder11
Thanks in advance
I also have a 2000 C5. A strong magnet works fine to reset the '97-'04 C5 TPMS-IF what you have are the actual '97-'00 TPMS. The '01-'04 will NOT WORK on the '97-'00 models if using a special tool OR powerful magnet. If your TPMS are for your MY car, you don't need any special tools.......
Last edited by grinder11; Nov 24, 2020 at 11:24 AM. Reason: Spell and more info to add
Old Nov 29, 2020 | 04:25 PM
I am not aware of any TPS that work with that many model years. The 97-00 sensors are not compatible with the 01-04 cars, at least for the OEM sensors. If they do not program when you follow the service manual sync procedure, I doubt they are going to work with your car at all. JMO.
Old Nov 29, 2020 | 04:27 PM
rob-cyn's Avatar
rob-cyn
Yeah its looking that way
Oh well. I will not have any for a while I guess as they are on the car now. Not taking them back off until I need tires
Lesson learned
Old Nov 30, 2020 | 01:40 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Apparently the dorman 974-301 will work on the 97 to 2000 C5. I used this on my 04 and it says it's compatible with the 97 through 2000 C5. It does have to be programmed with the dorman tool to the car and you need another $10 tool since tool the magnets didn't work for me even though it said it does.
Old Nov 30, 2020 | 01:53 PM
C5MSG2004Vert
Thanks in advance
These may have been the right ones, but if you did not program them to your car before you installed them they won't work. These universal sensors are "blank" when sold and they have to be programmed to the specific vehicle they are going to be used on. Maybe the instructions for the sensor have the information on how to program them. You can actually clone your old sensors to some of the new universal sensors and just install them in their original locations and they will work.
Old Nov 30, 2020 | 05:58 PM
rob-cyn's Avatar
rob-cyn
No instructions, the vendor did write back and say that they can be paired up with on obd2 tool
I may try it if I get a tool but for now I am done messing with it
Should have made sure I got the right parts by looking to see what people on here were buying
To New TPMS Sensors
