C1284 / C1285 Codes
Old Nov 29, 2020 | 10:34 AM
c5-issues's Avatar
c5-issues
4th Gear
Default C1284 / C1285 Codes
I am trying to run downC1284 and C1285 errors. My scantool does not let me see the live values of the lateral accelerometer voltage. What scan tool should I get on a budget? I have autotel al519 now. I assume it cannot be as easy as replacing the lateral sensor. Also recommendations for a good ebcm repair company.
Thank you in advance!
Old Nov 29, 2020 | 04:12 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Moved this thread to Tech !!
Old Nov 29, 2020 | 05:34 PM
feeder82's Avatar
feeder82
https://www.absfixer.com/ gets a lot of mentions for ebcm repair on this forum. what year is your vette? older than 2001 your out of luck
Old Nov 29, 2020 | 05:55 PM
c5-issues's Avatar
c5-issues
4th Gear
Mine is a 2003. I have read about absfixer but seems like everyone said to stay away. I am also reading that if your code is c1284 it is not repairable, not sure if that is true or not. I would love to hear from someone that may have used absfixer or had this code. Just crazy as many people have trouble with these parts and nobody makes them remanufactured.
Old Nov 29, 2020 | 06:42 PM
Smoken1's Avatar
Smoken1
There are places that do the same thing for alot less
Old Nov 30, 2020 | 09:37 AM
C5 Diag's Avatar
C5 Diag
You may have a bad sensor, wiring, or EBCM. You can measure the voltages right at the sensor...it's 3 wires...5 volt ref., a low ref.(ground) and a signal wire. How much you looking to spend ??...you can get a Chinese clone Tech 2 for $300-$400 dollars...best thing is that it has bi directional capabilities !!
Old Nov 30, 2020 | 05:56 PM
c5-issues's Avatar
c5-issues
4th Gear
I measured at the connector and it read 4.95v. It is supposed to read .15v - 4.85v, but that is without the accelerometer connected. I really would prefer not to spend $300 on a scanner. I like buying tools but thankfully I have used the cheapo scanner I own maybe one time. It bi-directional capability what I am looking for?
Old Nov 30, 2020 | 06:30 PM
C5 Diag's Avatar
C5 Diag
You still need to check the low reference and signal...you would jump the 5 volt ref. to the signal and see if the PCM via the scan tool is seeing 5 volts but unfortunately you can’t see that voltage with your scan tool... you may just have to shot gun parts and hopefully it won’t cost you more than a Tech 2 would cost...you don’t need a bi directional scan tool but it would help down the road with future issues you may have...nice being able to turn things like fans, pumps, solenoids, etc on and off.
Old Dec 7, 2020 | 03:22 PM
Jason Bailey's Avatar
Jason Bailey
1st Gear
Default 2001 2002 2003 2003 Corvette ABS EBCM Repair
We repair these. We.ve repaired thousands over the years. We can also test relay and diodes that are common for failing and have parts available to replace if needed. We operate under 2 names. Our business in DFW where we've been for almost 50 years, AC Speedo Electric at 1231 Colorado Ln in Arlington, Texas 76015 and also on Ebay at Texas Speedometers.
We can be reached at 817-460-7788 M-F 9-5
Old Dec 8, 2020 | 02:48 PM
c5-issues's Avatar
c5-issues
4th Gear
Thanks Jason, I have found the problem. It was the lateral accelerometer, thankfully.
Old Dec 9, 2020 | 10:36 AM
knewblewkorvette's Avatar
knewblewkorvette
I just used your repair service by eBay and have received my EBCM back, I just haven't installed it yet. Very quick turnaround.
To C1284 / C1285 Codes
