Differential damage? Anyone see this before?
Old Dec 3, 2020 | 08:45 PM
rockymountain1999's Avatar
rockymountain1999
2021 C6 of the Year Finalist - Modified
Default Differential damage? Anyone see this before?
I’m replacing some seals and installing a new clutch. I separated the differential from the transmission and discovered this damage inside the differential. Has anyone seen this on their differential? This may be reason I have a small leak here. Not sure what, if anything, I should do here.
Old Dec 3, 2020 | 08:55 PM
robmiz's Avatar
robmiz
The two I have rebuilt are both like that... normal too me...
Old Dec 3, 2020 | 08:56 PM
oharal's Avatar
oharal
It's normal. I cut the ever living ***** out of my finger in there once.
Old Dec 3, 2020 | 09:03 PM
rockymountain1999
Strange but ok. I was hoping I could have told the wife I needed to replace the diff with 4.10s but I guess I’ll stick with what I have.
Old Dec 4, 2020 | 07:18 AM
oharal's Avatar
oharal
I'll tell your wife you need 4.10s if it'll help your case
Old Dec 4, 2020 | 09:05 AM
grinder11's Avatar
grinder11
I like your thinking!! Honestly, it looks like a cast in "window", like a spot to maybe see the pattern on the gear teeth more clearly. I've never had the cover off, so I don't know what its for, but judging by the gently radiused "lip" you see on each side leading to the area you're referring to, it looks like it was cast in, and is probably on every C5 diff....
Old Dec 4, 2020 | 09:22 AM
feeder82's Avatar
feeder82
This is my RPM diff looks like they smoothed out that cut
Old Dec 4, 2020 | 05:15 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its very normal and NOTHING to be concerned over..
On another note, While you have the DIFF OUT, it would be an excellent time to disassemble it and check for broken limited slip differential clutch Belleview springs. More C5 differentials have broken springs that non broken springs. I have an 02 ZO6 and mine were broken/cracked at 40K miles. I replaced the springs with the better C6 ZO6 springs and also installed new limited slip clutches as mine were worn because of the bad Belleview springs.
I also installed C6 ZO6 output shafts which are much stronger and better design that the Whimpey C5 shafts.
NOTE.. Make sure that you replace the large O ring that seals the differential to the transmission. Otherwise you will have an differential lube leak.
Bill
Old Dec 4, 2020 | 09:57 PM
rockymountain1999
Good points. I’ve been reading about the springs and half-shafts. I’m a bit nervous to tear into that far but I’ll probably end up doing it.
Old Dec 4, 2020 | 10:05 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ya know, As mechanical as I am, I had the same fears. It really isnt that difficult or complicated. There are ZERO alignments that need to be done to reassemble it. The ONLY part that slows people down is using a press to compress the one clutch pack so you can slide in the spider gear cross shaft. I made a little tool out of a piece of heavy wall pipe and it went very easy. Trust me,, If I can do it, you can.
Old Dec 5, 2020 | 10:56 AM
Rx7Rob's Avatar
Rx7Rob
Very little force is required to compress the spring. I used a deep socket on either side of the cross shaft and pressed on the sockets.
Old Dec 14, 2020 | 09:02 PM
MAVetteGuy's Avatar
MAVetteGuy
I second Bill's statement. Every new project seems daunting but this one isn't all that bad. Just take your time and let us know when any questions pop up. I replaced my springs years ago, I can almost guarantee yours will be broken too, you did the hard part of taking the diff out already.
Old Dec 14, 2020 | 09:37 PM
rockymountain1999
The project is going smoothly. My two washers were broken; wonder where those chunks of metal went?
I just PM’ed Bill about not having any spring pressure on my cross-shaft.
All the parts will be here soon. I’m looking forward to getting this part put back together.
Old Dec 15, 2020 | 02:15 PM
helga203's Avatar
helga203
that's normal. All your clutches are springs are total. I pulled my shaft out with no psi. But putting it back in is a completely different story.
Old Dec 15, 2020 | 02:21 PM
acroy's Avatar
acroy
Thanks for sharing. Good luck, keep us posted!
Old Dec 15, 2020 | 02:39 PM
MetalMan2's Avatar
MetalMan2
Agreed, broken springs and heavily worn clutch packs means no force to remove cross shaft. But getting it back in with new clutch packs and C6Z springs... it'll take some force.
My obligatory toasted clutch packs and Belleville springs picture:
Original belleville springs beyond broken.
And like you, I had missing chunks of spring...
Old Dec 15, 2020 | 05:12 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It is most likely stuck to the magnets in the bottom of the case. If your spider gears are not broken, your very lucky and that part of the broken spring just fell all the way down to the bottom. You have my number and if you need to call me. With broken springs, there qill not be any pressure or force on the clutch packs and that cross shaft will just slip out. When you put the new clutches and springs in, you will have to compress that one clutch pack and spring to get the shaft in.
Bill
Old Dec 15, 2020 | 09:26 PM
69's Avatar
69
Cruise-In VI Veteran
For your broken spring washer clean your coin magnet, my thread here> C5 [PICS] Differential Clutch Packs Replacement Tips - CorvetteForum - Chevrolet Corvette Forum Discussion
For the spider gear cross shaft, see below.
Cheers,
Goose
Old Dec 15, 2020 | 09:49 PM
rockymountain1999
Thanks everyone for the information and photos!
To Differential damage? Anyone see this before?
