295/40/R18 rear with 1/2" spacer,?
2000 vert, can I run 295/40/R18 on OEM Silver 5 spokes using a 1/2" spacer, will they fit?
Last edited by grinder11; 12-14-2020 at 09:25 AM. Reason: Spell and more info to add
When I bought my car it came with new 245/45/17 (25.7" high) on the front and 255/45/18 (27" high) rear. I did not realize I could go as wide as a 315 on the rear without rubbing. The 315/30/18 is 25.4" high and 12.4" wide.
That seems too wide for a 9.5" wheel. Also, I can't go with a shorter rear than front without giving me traction control issues, from what i've read. I was not planning on replacing the front tires right now, so I would have to go taller in the rear, that is why I was thinking 295/40/18, plus it should not be a problem on the 9.5" wheel. Would a 305 be too wide for a 9.5" wheel?, I could run the 305/35/18 (26.4" high). New wheels are on the wish list for the future but not in the budget right now.
grinder11, are you running stock wheels?
Received 1,899 Likes
A 295 is probably a little too wide, for an 18x9,5 rear wheel. A 285/40/18 is right at 27" tall and that would work fine. No reason to use spacers as they just aren't needed.
