2000 Remote
Old Dec 18, 2020 | 09:54 AM
RPGR90s's Avatar
RPGR90s
Default 2000 Remote
Hopefully this isn't a dumb question, but does my 2000 C5 have a unique remote?
One of mine is dead and I've done all the tricks with new batteries, repairing cold solder joints with no success.
I thought I read that the 2000 series were different so want to make sure I replace with the correct one.
Thank You!
RPGR90s
Old Dec 18, 2020 | 07:55 PM
thevelvetglove's Avatar
thevelvetglove
Yep, the 2000 is special and will cost roughly $80 delivered off ebay. My 200 has this number on the remote 10432147
Old Dec 19, 2020 | 10:36 AM
grinder11's Avatar
grinder11
That part# has been superseded with a new part#. I can't recall the new one right now. Search is your friend, and you'll find numerous options. The 2000 remote is NOT a special, one year only FOB. the '99, and other MY remotes will also work fine. The '01 and up will NOT work on the '97-'00 models.
Old Dec 19, 2020 | 02:17 PM
grinder11's Avatar
grinder11
Thank You!
RPGR90s
Corvette Recycling has an excellent used #10432147 Fob for sale today for $49.99. You may want to give them a shout. The new GM part# that supersedes the 10432147 fob is 19299230. Hope this helps......
Old Dec 20, 2020 | 01:19 AM
C5tx's Avatar
C5tx
Not to be pedantic, but the 2000 FOB is, indeed, a special one year only FOB.
Although any of the '97-'00 FOBs will work with '97-'00 C5s, the '97-'99 FOBs have the passive switch. The '00 FOB is the only one in this group that does not have the passive switch.
Old Dec 20, 2020 | 12:45 PM
grinder11's Avatar
grinder11
That may be true technically, but all that matters is other years will work if you can't find the 2 part numbers I listed above. I believe the 19299230 number I posted works with all 4 years ('97-'00), and has no passive switch.
Old Jan 25, 2021 | 11:56 PM
Mav67's Avatar
Mav67
Thanks to all of you on this, any info on the heater control unit blanking out dead and then just started working agai
Old Jan 25, 2021 | 11:58 PM
Mav67's Avatar
Mav67
Again?
or the turn signals? I see posts about a hazard switch or an additional harness at the knee bolster what is the best way to go for a permanent fix?
Old Apr 9, 2021 | 01:10 PM
LowMiles's Avatar
LowMiles
This online dealer shows that the 10432147 was for 2000 only has been superseded by 19299230
If your car is being judged by NCRS, you would need to bring this page to prove 10432147 is correct key fob for 2000.
I have an early build (August 1999) 2000 Corvette that has a number of 1999 parts dated 1999.
https://www.wholesalegmpartsonline.c.../10432147.html
Old Apr 9, 2021 | 02:47 PM
grinder11's Avatar
grinder11
My March 2000 build also has the 10432147 FOB......
To 2000 Remote
