Coolant sensor OHM range?
Old Dec 27, 2020 | 10:56 AM
87bob's Avatar
87bob
Veteran: Coast Guard
Default Coolant sensor OHM range?
I am doing a swap of an LS (LQ4) into a C4. And yes I know this is a C5 section. What I need to know is what is the OHM range of each of the sensors for both the LQ-4 and the LT-1. I am hoping to use the LS engine coolant sensor in the 93 car. In order to do this I need to know the OHM range. Making up a pigtail is easy. I do not want to machine the LS head to accept the larger LT-4 sensor. Thanks in advance for any help you can offer.
