Ignition switch
Old Jan 4, 2021 | 08:23 PM
Zeke Freudiger's Avatar
Zeke Freudiger
6th Gear
Default Ignition switch
My ignition switch isnt turning all the way off. The cylinder stays in the acc position if I jiggle it to the off position security issues arise. Found a used switch/cylinder combo with key of course on eBay for cheap looks like an easy change out. But my question is will computer need to relearn the key or be programmed for the new key? Or is it just easy plug and play?
Old Jan 4, 2021 | 08:57 PM
rockymountain1999's Avatar
rockymountain1999
2021 C6 of the Year Finalist - Modified
I recently switched out my ignition and cylinder. I used my original key and rekeyed the new cylinder to my keys. The key fits snug now and no error codes. No “relearning” required as long as you use the same keys.
Old Jan 5, 2021 | 07:54 AM
tentuna's Avatar
tentuna
There are no smarts in the ignition switch, so a swap will not require any relearn in the BCM the resistor in the key is read by contacts in the bezel portion, I will look through the post for ignition switch repair, since worn contacts will wreak havoc and endless error on the electrical system
Old Jan 5, 2021 | 08:59 AM
bjones7131's Avatar
bjones7131
Do U have to re-key the cylinder to fit your current key as previous guy indicated? I thought you used your old cylinder with the new switch electrical part so no re key. Thanks
Old Jan 5, 2021 | 09:20 AM
Moved to C5 Tech.
Old Jan 5, 2021 | 01:46 PM
feeder82's Avatar
feeder82
Brand new GM ignition switch is only $70 on rock auto
Old Jan 5, 2021 | 01:57 PM
rockymountain1999
....and moving the tumblers from your old cylinder to a new one isn’t too difficult as long as you keep track which ones go into each slot. This is probably where your problem is; a worn out key cylinder or a worn out key.
Old Jan 5, 2021 | 05:32 PM
mmartinez's Avatar
mmartinez
Anytime you change keys, you have to make sure that the key's resistance value is the same as the orginal key, if not you have to perform the relearn procedure.
To Ignition switch
