F45 code
Old Jan 10, 2021 | 05:18 PM
tom bulat's Avatar
tom bulat
Cruising
Default F45 code
After installing resistors that supposed fix issue and delete maximum speed 80 miles/hour, problem still exists !!! Does anyone know solution other than tech 2 which I don't have it ?
thanks tom
Old Jan 10, 2021 | 05:42 PM
grinder11's Avatar
grinder11
thanks tom
We're your resistors purchased OTC, or did they come in a "delete kit"?
Old Jan 10, 2021 | 06:05 PM
tom bulat's Avatar
tom bulat
Cruising
Regular 10 w 10ohm resistors
Old Jan 10, 2021 | 06:14 PM
Smoken1's Avatar
Smoken1
What codes do you have?
Old Jan 10, 2021 | 06:35 PM
tom bulat's Avatar
tom bulat
Cruising
Maximum speed 80 miles/hour
Old Jan 10, 2021 | 06:54 PM
Smoken1's Avatar
Smoken1
Did you use the DIC to check for any RTD codes?
Old Jan 11, 2021 | 06:13 AM
tom bulat's Avatar
tom bulat
Cruising
Does not work for F55 code
Old Jan 11, 2021 | 01:35 PM
Smoken1's Avatar
Smoken1
You need a Tech 2 if you have the F55 system
Old Jan 11, 2021 | 02:16 PM
grinder11's Avatar
grinder11
Agree. OPs thread says F45. Resistors work on F45, and on the '03. The '04s, according to Lyle@C&S Corvettes, have no way of tuning out or using resistors to fool the BCM. Lyle told me the '04s can only be fixed by replacing the OEM shocks with OEM, $600-$700 (each!) shocks. If anyone knows different, please post up. C&S is usually spot on.....
Old Jan 12, 2021 | 11:59 AM
tom bulat's Avatar
tom bulat
Cruising
In my case. resistors don't work on my '03 Did I do something wrong ? I cut connectors and wire to resistors Anything else I should do ?
Old Jan 12, 2021 | 01:44 PM
Smoken1's Avatar
Smoken1
On the 2003 you must use a Tech 2
Old Jan 12, 2021 | 08:12 PM
grinder11's Avatar
grinder11
On second thought, I believe Lyle did say the '03 requires the Tech II, not the resistors. The '04s, however, have no workaround I'm aware of, except buying new $700 shocks (each).
Old Jan 12, 2021 | 08:20 PM
Smoken1's Avatar
Smoken1
Never heard about the 04 problem with a tech 2 not working I do know it will work on the 03's
Old Jan 13, 2021 | 12:13 PM
grinder11's Avatar
grinder11
The way GM, and probably all manufacturers are today, they probably set up the BCM to ensure that there's no workaround; the owners of the '04s have to start buying some of those overstocked expensive shocks! Don't know the exact cost of the shocks, but a good guess would be at least $600 each×4=$2,400+tax!!!!
To F45 code
