Headlights won’t open
Old Jan 15, 2021 | 09:16 AM
vincesz06's Avatar
vincesz06
Default Headlights won’t open
Headlights turn on won’t flip up
Old Jan 15, 2021 | 10:14 AM
bjones7131's Avatar
bjones7131
Open hood and manually crack them open and try opening with switch again.
Old Jan 16, 2021 | 10:53 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
There are separate fuses for the motor that raises them, and the illumination. I'd start by looking at fuses.
Old Jan 16, 2021 | 03:52 PM
KnightDriveTV's Avatar
0KnightDriveTV
Former Vendor
If neither open, then it'd require more than one fuse is blown then...I'd start earlier in the system...i.e. the switch. My car sat for some years and actually wouldn't open the headlights either...once I worked the switch back and forth it worked fine. Same happened with the windows. Like anything, there's a diagnostic workflow but, if neither open or work, then it's going to be starting with verifying the switch is working.
Old Jan 16, 2021 | 11:54 PM
Alley Oop's Avatar
Alley Oop
Start with insuring the battery is at full charge. A battery at full charge will measure between 12.7 and 12.9 volts or more when measured across the battery posts with the neg cable disconnected. Don't bother with the dash voltage gauges as they report the state of health of the charging system and NOT the state of health of the battery. I would also get the battery load tsted. Most parts stores will do that free.
Once the battery is KNOWN good you can check the condition of the headlight control module. It is the HCM that senses current flow in the headlight motor circuit and shuts off the motor when the current rises to a set amount. The HCM is known for having the plastic case of the module fail allowing moisture and dirt into the electronics. HCM looks like this:
http://www.ebay.com/itm/97-98-99-00-...5Y0ETl&vxp=mtr
and is located on the passenger side below the headlight assembly.
Nope... Not weird at all. Pretty common C5 headlight problem.
Close bump stops are worn/damaged or missing. When the motor closes the headlight doors the bump stops are contacted causing the current in the motor circuit to begin to rise. The headlight control module senses the current rise and shuts off the voltage to the motors. If the bump stops are missing or damaged the motor over rotates the doors before the voltage is shut off causing them to have excess tension on the gears that will shut off the motors on the OPEN because the current in the circuit rises before the doors open and the control module thinks they have opened and hit the bup stops for open.
Examine the bump stops for CLOSE and turn them around if they can be or order replacements. Here is a link to a thread that shows both the open and close bump stops:
https://www.corvetteforum.com/forums/...ght-shake.html
GM no longer has replacements so order from the only source I know of:
http://rodneydickman.com/catalog/pro...roducts_id=309
Old Jan 17, 2021 | 02:29 AM
Moved to C5 Tech.
Old Nov 19, 2024 | 09:56 PM
Yellowc5z0666's Avatar
Yellowc5z0666
2nd Gear
Default Issue with my headlights aswell (2004 c5)
Im having an issue where my left headlight wont open, my right opens just fine but whats odd to me is the left one will open by hand and the right wont, also the little **** next to it (im very un mechanically skilled) im assuming this is the motor. The left side spins by hand very loosely and never gets tight where as the right side is tight to turn. Is this a headlight motor issue or could it be something else?
Old Nov 20, 2024 | 07:59 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If there is a local Corvette Club in your area call them and ask if they can refer you to a shop that may be able to repair it…good luck !!
Old Nov 20, 2024 | 08:46 AM
bjones7131's Avatar
bjones7131
Sounds like motor gears are stripped
Replace motor, motor is around 130.00, 30 minute job, several youtube how to out there.
Old Dec 29, 2024 | 07:37 PM
natasharomanoff's Avatar
natasharomanoff
Owner Foxbat Motorsports
Pro Mechanic
Default Thank you
Thank you, I had forgotten about the bump stops and it fixed my reoccurring issue with my right headlight not wanting to open.
To Headlights won’t open
