New mgw shifter question
Old Jan 20, 2021 | 09:11 PM
thot's Avatar
thot
8th Gear
Default New mgw shifter question
Hello,
I just recently installed a new MGW shifter on my 1999 C5 Corvette. I followed all the instructions perfectly and now when I try it out everything is perfect except for the fact that it stays in the neutral position between 5th and 6th gear and won't snap back to the middle position unless I push it there. The video that I will attach will be better at describing it than I can in text. Could this be because the bushings are brand new? Or maybe this is normal and I'm just overthinking it. If these questions could be answered that would be awesome.
File Type: mov
Old Jan 21, 2021 | 10:25 AM
F1Fan's Avatar
F1Fan
Look into the the anti-venom detent mod
I just added an MGW not very long ago, did not have this issue, maybe because I'd already done the anti-venon mod (did 1 of the 2 washers)
Also let me add, when your working in the garage doing the shifter, moving it around a bunch, once you get it out and drive it, it might clear up a bit more
Old Jan 21, 2021 | 10:54 AM
MetalMan2's Avatar
MetalMan2
Anti-venom mod only affects fore/aft movement of the shifter, not side-to-side. Also if anti-venom did anything to the side-to-side, it would only make OP's problem worse.
I tend to agree with this. The shifter might just be a little tight, and a little break in period may reduce some of the drag when it returns to neutral from 5/6 position.
In the trans there is a spring used to control the side-to-side shifter movement. This spring rotates the shift rail. These springs tend to weaken with age and contribute to the problem you're seeing. I noticed somewhat similar behavior when I had a MGW and with my TMOD lower box, albeit not as severe as yours. My car only has 70k miles.
Old Jan 21, 2021 | 11:24 AM
robmiz's Avatar
robmiz
Looking at your video, my guess I think you might have that shifter base mounted too far back. You might want to move it slightly to the center of the bolt slot.
Picture of your shifter position.
On the T56, there metal guide groove and a tab that ride within it, that tab might be making slight contact with the guide.
Old Jan 21, 2021 | 11:43 AM
punk86's Avatar
punk86
I think I remember having this problem, too. I believe it has to do with the sound mat you install in the tunnel from the top. Where it's right under the shifter. You just need to break the shifter in for like 100 miles.
Old Jan 21, 2021 | 05:12 PM
thot's Avatar
thot
8th Gear
Thank You!
I'm going to look into all of this
Old Jan 21, 2021 | 07:12 PM
Chogan835's Avatar
Chogan835
Originally Posted by thot
Hello,
what did mgw say?
Old Jan 21, 2021 | 08:26 PM
Sean_emory's Avatar
Sean_emory
Did you use the alignment tool?
Old Jan 22, 2021 | 10:12 AM
F1Fan's Avatar
F1Fan
It's possible to get the alignment off where the bolt goes into the detent from the shift rod, mine was off like maybe a 1/16" of an inch, and it was popping out of 1st and 3rd until I realigned it.
Old Jan 22, 2021 | 01:20 PM
lionelhutz's Avatar
lionelhutz
Mine has done that for many years now. It's a weak return spring in the transmission. There is at least one aftermarket shifter with centering springs to help this issue.
I've messed with alignment a number of times and it's as good as it can get.
The anti-venom mod has nothing to do with this issue.
Do double check the alignment. Don't just use the pin but rather move it around and keep checking that the holes line up. The pin has a little play and lets it be slightly off.
Old Jan 22, 2021 | 01:31 PM
MetalMan2's Avatar
MetalMan2
When you're referring to the pin, do you mean the pin on the stock shifter/lower box, or the alignment tool that comes with MGW shifters?
Old Jan 22, 2021 | 03:59 PM
Chogan835's Avatar
Chogan835
What does mgw say?
Old Jan 25, 2021 | 12:26 AM
thot's Avatar
thot
8th Gear
MGW told me that I have to recheck the tightness of the bolts and that I would have to actually drive with the shifter and get some wear into it.
Old Jan 25, 2021 | 03:25 PM
lionelhutz's Avatar
lionelhutz
My shifter went on the stock lower box. It uses the stock alignment. I really don't know what MGW sells now, but there has to be some way to align it.
Actually, it you play with it you can aligned it without any tools. Just get it straight up when it neutral between 3rd and 4th.
Old Jan 25, 2021 | 03:50 PM
MetalMan2's Avatar
MetalMan2
The current MGW offerings only include a lower box, and they come with an alignment tool. MGW put out a video which shows the alignment tool: https://www.youtube.com/watch?v=NS9x...ature=youtu.be
To New mgw shifter question
