cruise control
Old Jan 23, 2021 | 09:34 AM
4show's Avatar
4show
Default cruise control
still a newbie:
cruise control not working on my 2000 Z51 hatchback.
Old Jan 23, 2021 | 12:03 PM
grinder11's Avatar
grinder11
Originally Posted by 4show
still a newbie:
Have you checked the fuses?
Old Jan 23, 2021 | 12:12 PM
4show's Avatar
4show
duh.. what fuses are they and where are they located??
Old Jan 23, 2021 | 12:42 PM
grinder11's Avatar
grinder11
The C5 has 2 fuse box locations. One is seen easily, under the hood on the passenger side. The other is on the passenger side, but it's in the footwell, where the passengers place their feet. Didn’t your car come with an owners manual? The manual is usually kept in the glove box, but could be in one of the 3 trunk compartments. I suppose it could be in the console, under the hinged cover. Good luck....
Old Jan 23, 2021 | 03:14 PM
4show's Avatar
4show
Thanks. Yes I’m aware of the fuse box locations. What are the fuse numbers?
can the fuse be the only cause?
Old Jan 24, 2021 | 06:07 AM
4show's Avatar
4show
I see a related thread was posted but it’s for c7.
im 2000 c5. Just the fuse numbers
Old Jan 24, 2021 | 08:31 AM
feeder82's Avatar
feeder82
No, could be lots of things, brake switch, clutch switch, multi function switch, wiring issues to name a few
https://www.google.com/amp/s/fuse-box.info/chevrolet/chevrolet-corvette-c5-1997-2004-fuses-and-relay
Old Jan 24, 2021 | 08:55 AM
4show's Avatar
4show
Thank you very much, now I can trouble shoot other ailments ( like my horn). Just really trying to get into this car. I have a couple of other things to work on, will need you guys advice.
I will also try to use “search” here more and not ware you guys out. ✊🏼🙏🏽
Old Jan 24, 2021 | 09:16 AM
feeder82's Avatar
feeder82
I've found that using Google instead of the forums search works much better. I start the search with c5 Corvette and then what I'm looking for. Corvette forum is almost always at the top of the answers
Old Jan 24, 2021 | 09:18 AM
rjacobs's Avatar
rjacobs
This might give you a clue on why your cruise isnt working also.
Old Jan 24, 2021 | 09:53 AM
helga203's Avatar
helga203
Did you pull the codes?? When my cruise went out, this is how mine reacated. when i pushed to set it stayed on for about a second. I pulled the codes and it brought up tac codes watch i forgot which ones. Nothing else was wrong with the car so i changed it and been working for years. It's weird but it worked. Just my experience.
Old Jan 24, 2021 | 09:57 AM
4show's Avatar
4show
No I’m a newbie, haven’t done the code thing. What did you change?
Old Jan 24, 2021 | 10:22 AM
helga203's Avatar
helga203
Its a tac module Google it. Goggle how to pull codes. I dont know why it was the tac. It stummed me but it fixed the problem.
Old Jan 24, 2021 | 11:40 AM
feeder82's Avatar
feeder82
when you figure out how to pull the codes here's a list, what they refer to.
File Type: doc
Old Jan 29, 2021 | 09:20 AM
4show's Avatar
4show
I want to thank the forum for valuable answers to my questions. I indeed did all directed and learned a great deal concerning this vehicle.
I “pulled” codes for first time and discovered that I only had a few “H” codes from a window regulator repair I did. I then following the suggested procedure of adjusting the cruise control solenoid switch, worked like a charm. 👍
To cruise control
