Max transmission fluid temp?
Old Dec 9, 2002 | 11:21 PM
tgeers's Avatar
tgeers
Default Max transmission fluid temp?
Hi everyone,
What is the maximum transmission fluid temperature allowable? Last summer when at the drag strip my transmission fluid temp got up to 208 degrees. I was wondering if that is too high and I should invest in a transmission cooler. What do you guys think?
Old Dec 9, 2002 | 11:38 PM
TooManyIDs's Avatar
TooManyIDs
Default Re: Max transmission fluid temp? (tgeers)
Mine won't trigger a warning until it gets to 270.
Old Dec 10, 2002 | 01:01 AM
Face's Avatar
Face
Default Re: Max transmission fluid temp? (TooManyIDs)
:eek:
I've never seen mine go over 210!
Old Dec 10, 2002 | 01:25 AM
SFVetteman's Avatar
SFVetteman
Driving through the twisties and shifting manually, I've seen 220. Under relaxed normal conditions 180 is about average for me. Since heat is enemy #1 for an automatic, I plan on getting a deep pan and/or oil cooler. It's cheap insurance against a big expense down the road.
Old Dec 10, 2002 | 09:54 AM
TooManyIDs's Avatar
TooManyIDs
Default Re: Max transmission fluid temp? (Face)
Mine won't trigger a warning until it gets to 270. :eek:
That was on a road course (see sig). As best as I can tell, it seems to be around 205 normally.
On the Z06, there is no trans fluid display until you exceed 270. After that, it will stay on the DIC, even if the key is switched off. Once you cycle off the display, it won't come back on, if the temp is below 270.
Weird setup, I can't imagine why they just didn't make it a regular display setting.
Old Dec 10, 2002 | 07:38 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I think your temperature will tend to run higher with a higher stall converter also your outside temp will have an affect. I hit 212 in stop and go freeway driving, as the traffic flow picked up, my temp went down. So far the temp have ranged from 185 -212, just depends.
[Modified by wallstAL, 8:17 PM 12/10/2002]
Old Dec 10, 2002 | 07:51 PM
kromberg's Avatar
kromberg
Default Re: Max transmission fluid temp? (wallstAL)
When I was NA with mods, mine hit 258ish once running threes races one right after another. I think that was the start of my tranny taking a dump. A couple of hits from the 300hp Fogger was the nail in the coffin :D
Keith
Old Dec 10, 2002 | 07:59 PM
SilverStar's Avatar
SilverStar
Default Re: Max transmission fluid temp? (kromberg)
I had seen 230-240 running hard when I had a 2900 TC. With the 2400 and a cooler she maxs out at about 220.
Old Dec 10, 2002 | 10:09 PM
Purerock105's Avatar
Purerock105
200-220 when I was stock.
Running a Yank SY3500 now, and I went with a B&M
cooler at the same time.
160-180 now. And that's with 75 degree outside temps
and some hard runs to boot.
:cheers:
Old Dec 10, 2002 | 10:46 PM
tgeers's Avatar
tgeers
Default Re: Max transmission fluid temp? (Purerock105)
hey guys,
Thanks for all the replies. This giving a lot of knowledge I didn't have before.
Purerock105, where did you get the B &M cooler? I'm getting ready to install a SY3500 and a cooler might be a good addition.
To Max transmission fluid temp?
