Bad Oil Pressure Sensor -Options?
Old Nov 18, 2021 | 07:45 AM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Originally Posted by SteveBougon
Itried to put an extension on mine, and could not find any way to tighten it. Can't use a socket and a crows foot doesn't work.
You need to use a swivel socket extension at the oil pressure sensor. Then you will be able to unscrew it.
Old Nov 21, 2021 | 07:42 PM
irfgt's Avatar
irfgt
I have done dozens of them and have NEVER removed an intake manifold. An oil pressure sensor socket with a universal joint added to it with an extension will take it right out. Put it back in with a strip of paper wedged to hold the sensor inside the socket and screw it back in and tighten. 5 minutes done.
Old Nov 24, 2021 | 08:53 PM
oldspeedr's Avatar
oldspeedr
My sensor just failed today at 103,000 miles. Using the socket and swivel, do you need to disconnect/move anything like the pcv hose? I'm ok cutting a hole but I'd like to try the socket/swivel technique first.
Old Nov 24, 2021 | 09:30 PM
RedC5's Avatar
RedC5
Old Nov 27, 2021 | 08:35 AM
irfgt's Avatar
irfgt
I do not recall moving any hoses but even if you do there is no problem doing it.
Old Nov 27, 2021 | 10:00 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
If can change your own oil, you can pull the intake, and do it in less time.
Old Nov 29, 2021 | 05:00 PM
oldspeedr's Avatar
oldspeedr
Mine is a 99. And it's the pcv hose in the way. Even unplugged from the driver side grommet, it really restricts the socket. And it's still difficult to push back or up to leave room for the socket. I did the sender on a c4, have removed upper intakes on various vehicles to change plugs. With the car being 21 years old, I'm not afraid of the intake, I'm afraid of breaking something difficult to replace or expensive. I'll take a look at the pcv hose mount on the passenger side. Maybe I can get it to move back towards the firewall. If so, it looks to be an easy job. Not much harder than the c4.
Old Nov 29, 2021 | 05:37 PM
SteveBougon's Avatar
SteveBougon
the socket is 1 1/8 or 41mm
Old Nov 29, 2021 | 05:52 PM
SteveBougon
I just did mine on my 98. I would just be careful with the fuel injector connectors, and I recommend that you pull the master cylinder vacuum hose out with the manifold, and make sure you reconnect the small HVAC vacuum line when reinstalling. I didn't do the following, and I regret it. It helps if you lengthen the rubber vacuum hose on the manifold fitting. It makes reconnecting the HVAC line much easier.
Old Nov 29, 2021 | 08:20 PM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
anyone have suggestions if you break the small vacuum hose for the HVAC?
Old Nov 29, 2021 | 10:44 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Depends on how you broke it. A few links with diagrams and some fixes.
https://www.corvetteforum.com/forums...with-pics.html
https://www.corvetteforum.com/forums...e-picture.html
https://www.corvetteforum.com/forums...nge-vents.html
https://www.corvetteforum.com/forums...-manifold.html
