Battery
Old Nov 28, 2021 | 06:35 PM
John52749's Avatar
John52749
6th Gear
Default Battery
2003 anniversary model…battery is one year old, goes dead in a week of not running….was told by former owner to keep it on trickle charge….is this a common issue?
Old Nov 28, 2021 | 06:41 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I would not think so he snow balled you, there is short someplace, my car sits sometime in the garage for month and fires right up.
Did he replace radio, if so might be starting point it was hooked up wrong. If that isn't case, what is new in the car that it didn't come with that he might of added, is a good start.
Old Nov 28, 2021 | 06:48 PM
John52749's Avatar
John52749
6th Gear
Sounds reasonable….the only thing mentioned was the hazard button sticks and alarms when turn signals are used. I just got the car a week ago and intended to have that fixed, now more than ever. Thanks for the thoughts
Old Nov 28, 2021 | 07:07 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Your battery should NOT go dead in a week…a month yes a week no…you may have a parasitic drain…you will need your mechanic to diagnose this…the more your battery discharges it will not last very long and you will need to replace it again !!
Old Nov 28, 2021 | 07:29 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Check the battery Reserve Capacity rating. It should be 120 minutes (120RM)
Old Nov 28, 2021 | 07:34 PM
John52749's Avatar
John52749
6th Gear
thanks, will do that. I believe the culprit is the hazard switch has a short….
thanks again for the suggestion
Old Nov 28, 2021 | 07:56 PM
C5 Diag's Avatar
C5 Diag
Even a battery with an RC of 100 minutes should not go dead in a week. It is not the battery.
Old Nov 28, 2021 | 08:04 PM
Not a bad idea to keep the car on a battery tender when not being driven, but as others have said, the battery, under normal conditions, should not go dead in a week. Something needs checking to see why the battery goes dead in such a short period of time.
Old Nov 28, 2021 | 08:22 PM
Mike98SilVert
I agree it's not the battery reserve minutes causing it to go dead in a week.
There may be an excessive drain or maybe the battery is not being fully charged.
Just something to consider when you eventually replace the battery.
Old Nov 28, 2021 | 08:42 PM
ALLEGRO's Avatar
ALLEGRO
I totally agree with the "hive" here on your issue.
Things to remember include the fact that there is significant parasitic draw on C5's. Several things are "awake" even though the car is not on or being driven. I too recommend a trickle-charger when not using your ride more than a few days. In fact, I was able to nurse the OEM battery just short of 10 years due to the usage of a quality trickle-charger.
Also to remember, when the battery voltage does get low, our C5's do the very strangest things. Don't ask me how I know, but please take into account.
Good luck and enjoy.
Old Nov 28, 2021 | 09:35 PM
Justin Raney's Avatar
Justin Raney
How old is your battery? I had a 1 and half year old battery that would go dead in a week as well from the previous owner if not started every few days that was out a warranty by half a year. Replaced it with a 1 year warranty VP-78 from walmart for around 50$. My volt gauge reads 13.1 and 13.4 at times but under the engine fuse box the fuses would read 13.7 and 14.2 with the car running.
Old Nov 28, 2021 | 10:23 PM
John52749's Avatar
John52749
6th Gear
Battery is 13 months old, trickle charger on it now. Thanks for all the info.
Old Nov 28, 2021 | 11:11 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Do you have a multimeter? You can figure out if you've got a parasitic drain and which circuit is causing the problem. Several threads around where the process is explained.
Old Nov 28, 2021 | 11:21 PM
John52749's Avatar
John52749
6th Gear
Thanks, that is good advice.
Old Nov 29, 2021 | 02:06 PM
mmartinez's Avatar
mmartinez
There are two things you have to do, connect a DMM configured as a ammeter in series between negative battery terminal and negative battery cable and select 10A scale to measure current after twenty minutes with the car off. Normal sleep mode current us 25ma, if you do have excessive current draw you will have to measure voltage across the fuses, there is a video on how to do this.
Old Nov 29, 2021 | 02:58 PM
John52749's Avatar
John52749
6th Gear
Thank you
Old Nov 29, 2021 | 11:01 PM
vette4fl's Avatar
vette4fl
There’s another possibility…. Is your charging system working properly? Could be either it is not driven long enough to fully charge, or just not charging as fast as it should.
To Battery
