Tick master cylinder leaking
just wondering if anyone has every had a leaky tick master cylinder?
I have had mine on for abouts 3 years now and few miles on it and its leaking from the rubber boot.
Does anyone know what's the fix to this problem and why it's happening?
Thanks in advance
For general information, I went with a stock C6 master cylinder when I did my C5 clutch. A direct bolt on replacement, physically the body is a little bigger, but no functional differences. The filler cap is said to be improved over the C5 design, less moisture intrusion, I was told. Of course, it completely blows any chance of that first at pebble beach I was planning on down the road, once I get it washed.
another possibility is someone put in incorrect fluid that caused the seals to fail over time, either they expanded too much, or not enough. I had a guy ruin a transmission that took an odd ball fluid, and if your tick asks for a different fluid than stock, that might be it. One has to figure that in most shops repairing anything today, the guys who know how to do the work well are the supervisors, not the actual repairing person, because of the cost of labor.
I will order a new one but I hope this doesn't happen again.
I kept the fluid clean at all times and the angle was straight as well guess will never know.
Thanks in advance
I will keep an eye on the rod angle when I put it back together
this is my plan so far, not sure if there is proper way of doing this though.
Yes I know. But that's what the manufacturer recommended.
I will be eyeballing so will see I guess.
4 yrs later, seeping again.. never did see anyone saying how to change the angle, and what
determines if the angle is off 3 deg.. it is hard to figure out standing on my head under there.
maybe just go back to stock like others and be done with it.
any input would be appreciated.
Or you can open up the bolt holes to get some movement.
it was in the car when i purchased. 6 yrs ago.. and 4 yrs ago it seeps. did the rebuild kit and was fine. but the last few months i see the
master cyl down a bit.. crawl and see it seeping at the same place, where the boot is on the rod and connected to the fire wall..
not sure what to do.. maybe try one more rebuild kit..
thanks Helga for your input.
and drilling some holes in the bracket few other things. i m sure i just can t take the mc out and pop the oem one in. there must be more to it
i m thinking.. i should be able to retain the remote bleeder i think if i go OEM.
P.S. When i went for the first time to put it in. gear i almost put the pedal through the floor. I thuoight i fuked up the install.
