ARP crank bolt question
Old Feb 12, 2021 | 11:14 AM
lavaheadache's Avatar
lavaheadache
2018 C5 of Year Finalist
Default ARP crank bolt question
I’ve already completed the project but i have a little question in the back of my mind. I just finished up replacing my harmonic balancer. There was conflicting info in the directions and just went with my gut. In the ATI directions they state to use red lock tite and torque to 240 ft lbs if using an ARP bolt. ARP instructions stated to lube all the threads and washer and bolt flanges with their lube and torque to 235 with no mention of lock tite. I’m not sweating the 5 ft lbs discrepancy but I didn’t see how it would make any sense to use red lock tite and lube at the same time. I just lubed it up and snugged. What do members think? I can’t imagine the bolt is gonna back off.
Old Feb 12, 2021 | 12:00 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
I've never used Loctite on the ARP bolt. I use their grease on the threads and a film of RTV on the washer.
Old Feb 12, 2021 | 12:23 PM
lavaheadache
Thanks for the reply. I didn’t bother with rtv. I have a pin in the slot and I’m guessing between that and the grease it was enough for them to not bother recommending rtv. The do state to use the lube on the bolt flange and the washer faces I’m of the mindset that with the lube in there it’ll just contaminate the rtv anyway ruin it’s properties.
Old Feb 12, 2021 | 01:13 PM
MetalMan2's Avatar
MetalMan2
See a post I did last month on this: https://www.corvetteforum.com/forums...post1602869749
ATI says to use RTV. Grease isn't a sealant by any stretch. But let us know if it seals well enough.
Old Feb 12, 2021 | 01:30 PM
lavaheadache
I read. It seems as though you suggest that maybe their grease acts as a sealant. Yet here you suggest otherwise. I know what their instructions state as that’s what I followed. No pin use rtv, and if you pin there is no mention of rtv.
Old Feb 12, 2021 | 01:55 PM
MetalMan2's Avatar
MetalMan2
Let us know how yours turns out. I see where you're coming from, but I'm skeptical about not using RTV.
Old Feb 12, 2021 | 02:43 PM
grinder11's Avatar
grinder11
I've never torqued my balancer, and I'm on my 2nd engine. I put a little motor oil (yes, I have the ARP lube) on the bolt threads, get out my 35 year old Campbell/Hausfeld 1/2" drive impact, set it on #4, and let her rip. I'm sure I'll get some negative posts about this. All I can say is that the balancer has been on and off the current engine 3 or 4 times (cam changes), with absolutely no problems with the balancer spinning on the crank, coming loose, or stripping threads on the bolt or crank. The balancer was also on and off the previous engine at least twice, for the same reasons. It would take a tremendous amount of torque to strip a thread that size (19mm?), so I've never worried about it. But my way may not work for everyone. My impact is 35 years old, and probably has only 250-275ft/lbs of torque. You're on your own if you try setting a new 1/2" drive "earthquake" impact on high, because they have over 600 ft/lbs of torque. My way works for me. But you may try it for yourself if using an old impact like mine, or setting a newer, more powerful impact on setting #2 (of 4 possible settings), or halfway on the #1-#4 setting. Saves alot of work, and time, for me at least.
Old Feb 12, 2021 | 04:42 PM
jim993's Avatar
jim993
You should email or call ARP to clarify this. No answer from your email? CALL.
Old Feb 12, 2021 | 05:04 PM
grinder11's Avatar
grinder11
I agree Jim. He should just call. Phones are still a great way to communicate. Emails sometimes go unnoticed. When phones ring, if you can't hear that, maybe you should be in a different line of work! Personally, I've never had a problem with the way I do it. I have an A4 car, so it makes a tough job a lot easier. Probably not for everybody, though.....
Old Feb 12, 2021 | 08:28 PM
lavaheadache
Guys, I did call call this morning right after I posted. ARP said that they don’t do lock tite with their bolt. Just grease her up and torque her down. I just wanted to know what forum members were doing with their cars and how things worked up for them. I live in the northeast and we are currently under heavy snow cover and salted roads so it’ll be a bit till I truly get to put it to the test but I did get the engine up to operating temps with a few revs and not a drop anywhere.
Old Feb 12, 2021 | 08:30 PM
Mr. Black's Avatar
Mr. Black
Usually LS engines with a leaky crank bolt just weep. I think they rarely if ever get where they're flinging oil. I have always siliconed them and never a leak or any weeping.
Old Feb 12, 2021 | 09:17 PM
lavaheadache
Out of curiosity, how much oil pressure is behind that bolt? I wouldn’t assume much.
Old Feb 12, 2021 | 09:29 PM
ThomasR's Avatar
ThomasR
No oil pressure. The balancer stops against the timing chain sprocket. Oil can get between the two and run along the key way hole, and leak out behind the crank bolt.
Old Feb 12, 2021 | 09:33 PM
ThomasR's Avatar
ThomasR
If you used an ATI balancer there shouldn't be a key way so no worries for oil leaks.
Old Feb 12, 2021 | 10:26 PM
Smoken1's Avatar
Smoken1
Odd mine has the key way
Old Feb 12, 2021 | 10:29 PM
ThomasR's Avatar
ThomasR
Maybe I'm mistaken.
Old Feb 12, 2021 | 11:08 PM
lavaheadache
Ati balancer has a key way. I did pin my crank while I was in there
To ARP crank bolt question
Old Feb 12, 2021 | 11:59 PM
jim993's Avatar
jim993
Some vibration damper manufacturers provide a method to drill a keyway and insert a key with their product. OEM has no keyway. From what I can tell, the typical OEM damper failure is the bond between the rubber damping layer and the inner rotating part and the outer belt sheave.
Old Feb 13, 2021 | 01:03 AM
Moved to C5 Tech.
Old Feb 13, 2021 | 10:03 AM
helga203's Avatar
helga203
Just throwing this out there If you can only toque down say 200 ft lbs dont freak out. I have IW CD and instruction said 140 lbs no grease no redtite. This was over 10yes ago 10rib pulley with procharger, over 1k hp. Just saying. I guess that's why there are anxiety pills. I love you guys.
