2003 DIC gauges
Old Feb 21, 2021 | 07:19 PM
jetvet9's Avatar
jetvet9
7th Gear
Default 2003 DIC gauges
I have a 2003 coupe with 22,000 miles on it purchased 2 years ago. Several times in the last couple of weeks, the DIC gauges light up brighter than the normal look. Only 1 gauge at a time-only 1 or 2 letters or numbers (the low temp and high temp with symbol only-not the entire gauge). The gauges read what they're supposed to, the read out doesn't indicate any problem and the HUD reads correct. Had it out for a run today and it did this 3 times on different gauges. Any ideas? Thanks.
Old Feb 22, 2021 | 12:19 AM
Tyteflows's Avatar
Tyteflows
Does the dimmer **** change the intensity of the brighter ones when you adjust it?
Old Feb 22, 2021 | 02:33 AM
Moved to C5 Tech.
To 2003 DIC gauges
