ECS Torque Tamer question...
Old Feb 22, 2021 | 12:28 PM
Fordracer9's Avatar
Fordracer9
Default ECS Torque Tamer question...
Should the hoop be installed under or over the wire harness that runs down the torque tube? Every fiber of my automotive background says under so it doesn't pinch it, but then its more than "just touching or clearing" the tube. The harness will "preload" the hoop on the tube a bit. There's no mention of positioning anywhere in the online instructions, or in the few threads I've dug up. I'll be lowering the rear cradle to ease installation, so either way will be possible. Just don't want to do it again if it's not right.
Old Feb 22, 2021 | 12:40 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Do not pinch the harness in there! That would cause a see of problems in no time. You want the tube to just touch the tube, not pulling on it at all.
Old Feb 22, 2021 | 12:49 PM
Fordracer9's Avatar
Fordracer9
Under it is then. Thanks!
To ECS Torque Tamer question...
By Michael S. Palmer | 2026-06-03 09:39:05
