Help - how do you replace idler pulley?
Old Dec 11, 2002 | 02:25 PM
sbkim's Avatar
sbkim
Default Help - how do you replace idler pulley?
Could someone give me some guidance on replacing the idler pulley? I have the torque specs and that you need 16mm but nothing more. For starters wow do you get the belt off the pulley?
Please help!
Thanks!!!!
Old Dec 11, 2002 | 10:32 PM
alanh's Avatar
alanh
Default Re: Help - how do you replace idler pulley? (sbkim)
Just a suggestion here, but mechanical work isn't everyone's cup-of-tea, so to speak. If you need help on instructions on how to get the belt off, I would suggest that you take the C5 to a professional to do the job. I think you and the car will come out ahead in the long run.
JMO and Good Luck
Old Dec 11, 2002 | 10:37 PM
CapeCodCoupe's Avatar
CapeCodCoupe
The bolt in the middle of the pulley will loosen! That's all it takes; then everything relaxes and off comes the pulley and sepintine belt! Go get em! :D
Old Dec 12, 2002 | 09:11 AM
sbkim's Avatar
sbkim
Default Re: Help - how do you replace idler pulley? (CapeCodCoupe)
Cape
Thank you - I guess that's all I need to know!
To Help - how do you replace idler pulley?
