Door Lock out of Sequence
Old Mar 15, 2021 | 05:47 PM
slapshift's Avatar
slapshift
5th Gear
Default Door Lock out of Sequence
Just bought a 2001. I just had both door control modules repaired. Functions work now but the driver door lock is not operating in proper sequence in relationship to using the fob or door control button. When you press lock the driver door unlock, press unlock and the driver door locks. Passenger door operates correctly. FOB's have been programmed . All connections are correctly installed and secure. Before I pull the actuators out wanted to see what people think it may be. TIA
Old Mar 16, 2021 | 01:56 PM
SilverC54me's Avatar
SilverC54me
Send the door control module back to who ever repaired it. They did something wrong internally while repairing.
Gary
Old Mar 16, 2021 | 02:09 PM
rrwirsi's Avatar
rrwirsi
Just asking but never repaired/replace mine, are you sure you hooked up the connectors to the proper areas on the module?
Old Mar 16, 2021 | 02:21 PM
slapshift's Avatar
slapshift
5th Gear
yep hooked up properly. Connectors are made to go in one place and one way
To Door Lock out of Sequence
